Results 1 to 10 of 10
Thread: Wife's e93 through this error message, anyone else experience the same?
    Feb 2014
    allentown
    99 Z3M coupe/09 MCS
    Wife's 2011 e93 through this error message. Before this the auxiliary fan seemed to be turning on and off frequently. On this day she said fan was not on. She drove the car 10 more miles home. Coolant level was good.
    Bellevue, WA
    335d, 328xd (had 330xi)
    The car is asking you to have the cooling system checked. Why don't you do so?
    Aug 2012
    Simi Valley, CA
    328, 525, 740, R1200RT
    Fan or pump are out.
    Feb 2014
    allentown
    99 Z3M coupe/09 MCS
    Quote Originally Posted by Old525i View Post
    Is there a way of checking the electric pump is good or bad? First time dealing with this kind of water pump
    Aug 2012
    Simi Valley, CA
    If the fan is roaring (running very fast and loud) all the time, the computer is trying to protect the engine from damage by trying to cool the engine as much as possible, perhaps due to a faulty electric pump. With the AC on, the fan should turn on. The engine computer also tests the fan by running it fast for a few seconds (more like 20 secs) after the engine is turned on.
    There is a way of purging air pockets out of the cooling system that can be used to check if the pump goes on, however, in my case, even though the pump went on during the test, the force of the coolant stream wasn't that strong and I had to replace it to restore the performance of the cooling system. While you are there, replace the thermostat as well. You can find lots of YouTube videos on how to trigger the test. It is a good idea to remove the fan to help in removing the pump upper bolt and some hoses.
    Feb 2014
    allentown
    99 Z3M coupe/09 MCS
    I replaced the thermostat last year while replacing her oil pan gasket. So I know the process of tearing everything out. I had the car running today for about 15-20 min to let it get up to temp and the fan never turned on. I checked the fuse and it was good.
    Jan 2016
    Ca
    2001 525it
    Electric water pump is done
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    you need to check the codes, but most likely the water pump is failing(it will throw a code)
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Feb 2014
    allentown
    99 Z3M coupe/09 MCS
    Only this message. No check engine light and No code to read. Haven't driven the car since this happened. Everything I've been reading looks like the pump.
    Feb 2014
    allentown
    99 Z3M coupe/09 MCS
    I replaced the water pump and also a leaking power steering hose ... But everything seems to be working perfect again... Thanks!
  1. Replies: 16
    Last Post: 11-13-2013, 01:24 PM
  2. Weird starting problem, anyone else experience this?
    By bennyfizzle in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2007, 09:32 AM
  3. system running lean, anyone else experience?
    By n20addict in forum 1995 - 2001 (E38)
    Last Post: 09-07-2005, 11:17 AM
  4. Does anyone else feel the same?
    By SilverE30 in forum Off-Topic
    Last Post: 08-09-2002, 05:17 PM
