I just discovered that, in the E34 535i air filter housing, there's a bellmouth intake tube.
It is part# 13711714362, item #13 in the picture above.
Does anyone know what is the purpose of it?
I find it very odd that this part is not installed in the E32 735i, although it uses exactly the same engine as the E34 535i.
Any feedback about how the engine runs with and without this intake tube?
1994 E32 730i M30 manual
ex- 2006 E86 Z4M Coupe
ex- 1986 E28 535i
Generally bellmouth ends are there to reduce turbulence as abrupt expansions create more turbulence. In saying that in the pic at least there seems to have a smaller opening so it comes of be some sort of acoustic sound attenuator. Try removing it and see what happens
BMW’s
90 E34 M5
84 E24 M635csi standalone ecu with coil on plug
94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
97 Z3 2.8
97 E36 M3 euro SC still u/c
OTHERS
11 Audi S5 APR stg2
19 Volkswagen Amarok V6
My understanding of the purpose to include a bellmouth tube in an intake housing is:
To diminish air turbulence while increasing air velocity.
So it would seem its purpose is to transform a standard airbox configuration,
to also exhibit the same efficiency and performance of a cold-air intake,
which truthfully, I believe it does.
My dinan bellmouth on the M60 airbox was just like that.
The E32 has the #11 in the diagram. My E34 has that bellmouth attached to the airbox. I also believe it acts like a cold air intake.
M60 intake has a narrow one like that. I had a wider Dinan piece on mine and can't say I noticed any change except a welcome slight increase in intake noise.
