Results 1 to 3 of 3
Thread: Radiator air duct repair question
    Apr 2006
    Bennington, VT
    no BMW's right now
    On my 2004 330ci vert I am doing some work on the front bumper. After removal I have some rubber flaps that are part of the radiator air duct that are dried out and falling off. Are these significantly functional to cooling or can I pull them off the rest of the way?
    If they are necessary the only repair I see is replacement of the entire air duct. Tried glue and melting to no avail.
    Randy
    Sent from my SM-T800 using Tapatalk
    Dec 2013
    Chicagoland area
    EXOTICS
    In extreme conditions you can be sure they will be "significantly functional to cooling",
    but under normal conditions you should be fine.
    Have you researched replacement part#'s on REALOEM?
    Apr 2006
    Bennington, VT
    no BMW's right now
    I have sourced the air duct part and it looks like an easy change. This is a non track car but it is 110 today in Texas.
    I think at one time there were some around the two upper openings behind the kidney grills. Not a great design - butt glued dissimilar plastic parts.
  1. air duct fastener question
    By fkat in forum 1999 - 2006 (E46)
    Last Post: 05-11-2014, 05:12 PM
  2. Cabin air duct repair?
    By Dunedevil in forum 1995 - 2001 (E38)
    Last Post: 01-02-2014, 08:05 PM
  3. radiator air duct project w FMIC
    By Sniz in forum Forced Induction
    Last Post: 07-18-2011, 07:55 PM
  4. 'O1 Bumper air duct cover question
    By blackie2 in forum 1999 - 2006 (E46)
    Last Post: 06-20-2006, 09:44 PM
  5. Brake Air Duct Sensors Questions
    By Professor in forum 1991 - 1999 (E36)
    Last Post: 09-28-2005, 04:23 AM
