Results 1 to 25 of 29
Thread: Can E39 door lock actuators be repaired?
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    I just replaced both rear door lock actuators on my 2003 540i6. They appeared to be origonal so a 15 year life isn't all that bad. However, I didn't see anything wrong with them. They were clean and nothing appeared broken. I'm thinking I can disassemble them, clean and re grease them and use them as spares.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Post some pics when you take them apart. Mine are 18 yrs old, never had any of them out.
    Never have had to replace a window regulator either....knock on wood.
    May 2014
    Will do...
    They weren't broken, just getting really slow.
    JimLev's Avatar
    Sundance Mesa, NM
    Then a clean and lube could be all they need.
    Oregon
    '99 528i/5, '01 Boobaru
    Quote Originally Posted by Santaclaus4 View Post
    Prying off the outer casing is about the only slightly difficult step as you don't want to crack it. The sliding and rotating gear parts inside are entirely plastic (probably delrin). The only thing that you might be able to replace is the small motor, which resembled the type used in certain slot cars, but the two challenges with that are finding motors that have the same polarity (don't work in reverse of how the motors in these units work) and that come with the small pinion gear attached ... You might be able to pull the original pinion gear off the shaft but, if my memory isn't deceiving me, it's brass and may not fit or stay attached to another shaft solely with an interference fit.
    I replaced my right rear door actuator not so long ago with a cheap aftermarket unit. So far, it is working at least as well as all the rest. The actuators in the BMW all make a buzzy zippy noise in operation. I can hardly hear the ones in my old Subaru.
    I suspect the reason they fail is that the tolerances in the plastic gearing simply get too loose after more than a dozen years.
    Sep 2016
    Phoenix
    E46 E39
    As cheap as the parts are, rebuilding them does not make economic sense.
    Getting the parts and pieces to replace the worn out parts within (if available at all) will probably cost as much as a new one.
    Oregon
    I agree. Lubing the old ones with a compatible lubricant to keep them around as spares is about the best you might hope for, but with functional aftermarket units going around $18, I don't think I'd even want to put an old one back in my car.
    May 2014
    With a lifespan of 15 ish years, it's probably a waste of time and storage space to keep the old actuators around. It was more about the satisfaction of fixing them up and just plain old gee-whiz. Never the less, I'll take one apart and photograph it for forum and personal curiosity.
    May 2014
    I finally took apart one of the old door actuators. I took pictures that I'll post a little later.
    I can't find anything wrong with it at all. The gears moved smoothly and still had lube on them. The electric motor felt smooth.
    The door locks must get slow due to worn or dirty contacts/brushes in the motors. I didn't disassemble the electric motor itself.
    May 2014
    May 2014
    This is what the actuators look like. I disassembled it a little further but can't upload the picture at the moment. I have more photos but I can't upload them at the moment.
    Apr 2018
    Socal
    00 528i, 01 540i
    I have two of these that i replaced too. I can't find anything wrong with the mechanisms either. There was a thread where someone actually replaced the motor. My guess is that the brushes inside have worn out and not making good contacts anymore for the motor. His problem the motor was not getting good contact and he redid the solder and it worked. Mabuchi FC-280PC-22125 is the motor, but ours has spline shaft these motors are just plain shaft.
    JimLev's Avatar
    Sundance Mesa, NM
    Thanks for the pics.
    How long do you think an $18 aftermarket actuated will last??
    Feb 2009
    Sweden
    '96 540i S/C
    I've tried. Took one appart, lubricated and such. Worked for 2-3 weeks. Turned out all the plastic gears was very slightly worn, and the housing flexed - so had to buy a new one. Even the off brand cheap china cones is ok, if you don't mind their noise...
    [E39 540i] - with S/C ESS kit (plus some upgrades)
    [E34 540iA] - Gone
    Nov 2011
    Mel, Aus
    5series M62B44
    I have a cheap ebay actuator in mine (Factory actuator lost a plastic tooth), it's locked/unlocked a couple hundred times so far. Apart from being slightly louder than what was from factory it works just great.
    Best thing I ever did was clean and lubricate all the locking/latch mechanisms driver door opens with a finger and sometimes I doubt if I shut it because it pops open at the touch of the handle now.
    Just need to do the other 3 doors... that's a job for future me
    Cheers
    Mat
    Quote Originally Posted by hakhawk
    I know first hand that owning a bmw isnt what made hozy the way he is, its just his charm
    Quote Originally Posted by geargrinder
    HoZY is good guy and has proven it many times by being a longtime participant in this community.
    May 2014
    I just tried to upload the remaining disassembly pictures but I get a message that says something like I've reached my forum limit. Something like that anyway.
    JimLev's Avatar
    Sundance Mesa, NM
    Were you trying to upload more than 5 pics in your original post? 5 is the limit unless you do it in a different post.
    Nate PM'ed me last week with the same message.
    May 2014
    I uploaded 5 pictures at the top of this thread, then I was able to upload 2 more. Now I can't upload anymore, even way down here.
    JimLev's Avatar
    Sundance Mesa, NM
    Try over on the TEST forum to see if you can post a few there just to see if it's a forum problem or a SC4 problem.
    May 2014
    Just tried to upload on the test forum and got the same message: file size exceeds forum quota by (this many) KB.
    JimLev's Avatar
    Sundance Mesa, NM
    Don't know what your file size is? I usually resize the pics to around 960 X 800. The actual JPG file is around 350KB.
    You using a PC or Apple?
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I can usually upload anything, including unedited, non-compressed iPhone photos and the website automatically downscales the images. However, when I tried uploading from my Canon t3i recently, I got a forum quota exceeded error. I did not attempt to resize them; I will try that next.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Sep 2011
    Riverside, CA
    2004 330Ci
    Just to add to the actuator info here. I recently replaced the one in my right front door and disassembled the old one for kicks. Below is just my observations and notes for what it’s worth.
    The actuator plug pin definitions, as deduced from the X1131 pinout.
    https://www.newtis.info/tisv2/a/en/e39-530i-lim/ZZYmw2b
    pin 1: ground to lock
    pin 2: no connect
    pin 3: 12V supply
    pin 4: ground to unlock
    actuator schematic
    https://www.newtis.info/tisv2/a/en/e...r-door/uQr4rAu
    - When directly powered on the bench, the defective actuator worked, but the motor ran slower than the fully installed actuators on the car. And this is running unconnected, with no load.
    - Resistance across the electric motor was about 6.4 ohms.
    - Lubricants on the screw shaft (yellowish grease) and gears (white grease) was still pliable and doing it’s job. Turning the large gear by hand revealed no binding in the gears, screw shaft, etc.
    - The grey plastic lever that rides on the screw shaft which does the locking/unlocking had a lot of side-to-side play, causing it to not always activate the micro switch. This is likely what caused mine to ultimately fail.
    - There is a discoloration on the plastic area between the motor’s electrical terminals and right under a passive component (capacitor?) connected across said terminals which suggests overheating at some point.
    - The replacement actuator was an OE VDO brand which was not cheap.
    - The original actuator had a revision code of 406.207/5/1 and date code of 2002.
    - The OE replacement actuator had a revision code of 406.207/5/2 and date code of 06.03.2017.
    - Although the screw shaft is about 2” long, the full travel for lock actuating is less than 0.5”.
    Sep 2011
    Riverside, CA
    2004 330Ci
    More photos...
    May 2014
    I have noticed something vaguely interesting. On both of my cars, it's the rear door actuators that failed, the front passenger door actuator is a little slow but still works and the drivers door is still original on both cars and the locks snap up and down like normal and at the same speed as the new rear actuators. I wonder if it's related to the rear doors not opening and closing as much as the front doors. The drivers door is the one that gets both locked/unlocked every time and open/closed every time.
    Maybe it's a coincidence but it seems like lack of use is a problem. I dunno...
  1. DIY: E39 Door Lock Actuator Replacement
    By fudman in forum 1996 - 2003 (E39)
    Last Post: 01-21-2019, 05:41 PM
  2. E39 door lock actuator OEM - No Longer Available
    By Belle528i in forum Exterior Lighting & Body Parts
    Last Post: 04-27-2015, 04:15 PM
  3. FS: E38 & E39 Door Lock Actuator - Brand New - VDO Siemens OEM - SOLD
    By bimmertrek in forum Interior Lighting & Body Parts
    Last Post: 11-07-2014, 04:08 PM
  4. E39 Door Lock Actuator Replacement
    Last Post: 06-26-2013, 10:56 PM
  5. E39 FS: New e46/X3 Ignition Switch and e39 Door Lock Actuator
    By Viper3812 in forum Exterior Lighting & Body Parts
    Last Post: 06-16-2008, 07:07 PM
