Results 1 to 3 of 3
Thread: Time for a bonnet respray - removing the washer nozzles
    Sep 2014
    Perth, Australia
    '92 740iL + '85 M635CSi
    I've decided it's time soon to get a full bonnet respray done. Too many stone chips in the leading edge to cope with now. This will be a car-on respray and only of the top surface, so I do not need to fully undress the entire panel or remove it from the car. I can deal with removal of the roundel badge easily enough, but I've never looked at how the windscreen washer nozzles are mounted. Has anyone done this before and knows how the nozzles come out without breaking all the no-doubt plastic spring barbs that are all brittle and designed to snap as soon as you dare to look at them?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    You have to remove the inner sound absorbing mat from the bonnet. Have done that some months ago on the B12 of my buddy, we had a spare hood which I brought to the paint shop and when this was finished we swopped the hoods. This will help, retrofit instructions heated windshield washers https://bmweba.com/eba-01-29-9-780-819/
    what will break from our experience?
    #6 expanding rivets, check beforehand, what type you have, that changed over the years https://www.realoem.com/bmw/enUS/sho...diagId=51_1816
    03 FRONT ENGINE HOOD SEALING 1 from 02/1987 51711946499 https://www.realoem.com/bmw/enUS/sho...diagId=41_0462
    the small rubber pieces which hold the sealing in place will rip off when you remove the seal from the hood, here pics https://www.ecstuning.com/b-genuine-...l/51711946499/
    Impossible to get it off intact with all the rubber nipples, we tried on the spare hood and the original hood, both sealings were not re-usable.
    Plus maybe some other plastic wire loom brackets attached to the inside of the bonnet, but that you will see when you remove it.
    https://www.youtube.com/watch?reload=9&v=vAJqoSkh7LI
    Sep 2014
    Perth, Australia
    Brilliant, thanks for that Erich
  1. How to remove windshield washer nozzle?
    By graycat in forum 1983 - 1991 (E30)
    Last Post: 01-31-2013, 08:34 AM
  2. Washer Nozzle Removal
    By Black Magic in forum 2004-2010 (E60,E61)
    Last Post: 09-06-2006, 10:15 PM
  3. Lower Headlight valance removal with washer
    By Odave in forum 1999 - 2006 (E46)
    Last Post: 01-08-2006, 02:57 PM
  4. Notes on removing washer nozzles...
    By argento in forum 1992 - 1999 M3 (E36)
    Last Post: 11-07-2005, 12:15 AM
  5. Washer nozzle removal
    By mbanks21 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-30-2005, 08:08 PM
