Results 1 to 4 of 4
Thread: NCS Expert suddenly stopped working
    Feb 2018
    Romania
    2008 BMW 530xd
    Hello! So here is my story:
    I am running Windows XP through VM with v65 Sp-daten, trying to code a 2008 530xd. Inpa is working normal and also I succesfully coded my car yesterday, then all of a sudden it stopped working. I coded the CAAPL, HUD and KGM modules and the changes that I made are working great, then I read the LCM and tried to code it, it gave me the "Datatransmission to inferface disturbed" error and since then I can t even read the car, it just gives me "FA fehler" error and the one I already mentioned. I have checked all the settings, tried updating ediabas and sp daten again, still not working.
    But there is this: after a fresh restart on the laptop, it reads the vin, vo and fa but right after i try to read any module it just stops working, giving the same errors, until the next restart, then i can read the vin, vo and fa again. So the cable and the settings are good but something stops the communication. Do you have any idea what could be happening?
    It is the same laptop and setup that worked fine yesterday, i haven t changed anything. I tried every solution I could find on the Internet and nothing worked, it s just really odd that it stopped working without changing anything and also that it works for a few seconds after a restart, then it doesnt work at all until another restart...
    Jul 2004
    Houston, TX
    36 Cylinders
    Make sure the ftdi cable latency is set to 1 or 2 milliseconds in device manager first.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2018
    Romania
    2008 BMW 530xd
    I did check that and it was already set to 1 as the interface worked before it stopped working without changing anything. I also tried to set latency to 2 and back to 1 again with no succes.
    Feb 2018
    Romania
    2008 BMW 530xd
    Ok so I m back with an update, I have installed "Mike's Easy BMW Tools package" directly on Windows 10 x64 and to my surprise NCS worked perfectly, I thought I can only run it on x32 machines, that s why I was using VM to run Windows XP. Still don't understand why it worked before and it just stoped working but now I m just satisfied that it s working again and even better I dont need VM anymore. I managed to code everything I wanted but now I do have another problem. INPA will not connect to the DME, it works fine on all the other modules but not the DME.
  1. Failed to remove radio, suddenly stops working
    By gotaction86 in forum 1991 - 1999 (E36)
    Last Post: 08-01-2007, 01:42 AM
  2. Auto trans SUDDENLY stopped working
    By BaliLover in forum 1983 - 1991 (E30)
    Last Post: 12-23-2005, 04:25 AM
  3. Radio suddenly stopped working
    By tuftex in forum 1991 - 1999 (E36)
    Last Post: 02-08-2005, 02:21 PM
  4. windows/ sunroof suddenly stop working
    By biggup21 in forum 1991 - 1999 (E36)
    Last Post: 08-10-2004, 12:13 PM
  5. Alpine screen bypass suddenly stopped working.
    By 318daily in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-28-2003, 11:59 AM
