RM European Auto Parts
Results 1 to 7 of 7
Thread: Changed Exhaust vanos coils and plugs WON"T START
    Jun 2018
    Winnipeg
    2008 BMW 323i
    I change the exhaust vanos and plugs and coils, now it won't start. 2008 BMW 323i, please help!!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Welcome to the forum.
    Obviously, you need to recheck your work. Did you tighten the 8mm nuts which hold the coil grounds in place? And, um, let's clarify what you mean by "changed the exhaust vanos". The exhaust vanos unit lives under the valvecover, and requires removal of the timing chains, and retiming the engine. Is that what you did, or did you just replace the solenoid?
    Chris Powell
    BMWCCA 274412
    Jun 2018
    Winnipeg
    2008 BMW 323i
    Solenoid sorry , I'm checking it all over now
    Jun 2018
    Winnipeg
    2008 BMW 323i
    It was the solenoid, I didn't have to remove the grounds, I checked a connections it's firering but I'm guessing its flooded
    Jun 2018
    Winnipeg
    2008 BMW 323i
    I've got misfires on 2 & 4
    Jun 2002
    E39M5, E500 4WD
    You need to know that these coils are very difficult to plug in. You cannot rely on the pivoting part to properly engage the plug to the coil. Press the plug hard into the coil while pivoting the clasp.
    I hope that you bought quality, OEM coils, and the correct OEM plugs?
    Chris Powell
    BMWCCA 274412
    Jun 2018
    Winnipeg
    2008 BMW 323i
    I check all connections and still had a misfire on 4, I swapped an old coil with the new one, running great. I must of gotten a bad coil (bosch), I will have to return it. No codes anymore, and my vanos exhaust solenoid code is gone. thanks for you help.
  1. Replaced plugs & 5 coil packs... car won't start
    By chumbie in forum 2004-2010 (E60,E61)
    Last Post: 01-14-2018, 07:09 PM
  2. Cost of changing Coil and Plugs in 04 545i
    By msund15 in forum 2004-2010 (E60,E61)
    Last Post: 05-05-2015, 06:32 AM
  3. Just got done changing my microfilter and spark plugs....
    By alexd in forum 1992 - 1999 M3 (E36)
    Last Post: 01-09-2005, 05:41 PM
  4. Changing my vanos cover gasket?
    By 95beema in forum 1992 - 1999 M3 (E36)
    Last Post: 08-18-2004, 10:11 AM
  5. Changing exhaust tips on a 330ci
    By AJY1013 in forum 1999 - 2006 (E46)
    Last Post: 06-28-2004, 06:29 PM
