Hello everyone, first post with this forum.
2005 BMW 545i
I was doing an oil change and noted the right side inner tie rod boot is cracked, the material was very brittle i guess.
Is there any way I can replace the boot without messing with the alignment?
I initially thought I can cut the old boot out and then unscrew the inner tie rod nut so I can slide over the new boot. I noted the boot comes with a narrow end on one side which wont allow it to go over the inner tie rod nut.
Maybe some has a better idea they can share!!
Thank you
***I have attached generic pictures for reference
You may replicate the rod length on the new one to get close. But you should still have an alignment performed.
Sent from my VS988 using Tapatalk
