Results 1 to 9 of 9
Thread: 1994 BMW 525i (E34) won't crank
    Jul 2018
    Costa Mesa, CA
    1994 BMW 525i
    Cool 1994 BMW 525i (E34) won't crank
    I bought my car used. The previous owner said he had $4k worth of work performed on the car a couple of years before I purchased it. He also said that he had a new timing belt installed. The car ran very good and tight as if brand new. I had a starting issue at first that seemed like the starter motor wasn't fully engaging the fly wheel. Had a new starter install by a good shop which solved the starter motor issue.The radiator blew a hole in the plastic part of the tank which made the car run hot. I had it towed home. In the process of figuring out why it continued to run hot after getting new radiator I discovered the cap was bad. Once I got everything replaced the car stopped cranking. The battery is fully charged but when I turn the key I get absolutely nothing. All dash lights come along with all electrical components seem to be fine with the car in the on position. I am mostly certain that something of an electrical presence is causing the starter not to crank. I have checked fuses in the fuse box on the left side of the engine compartment.
    I would like advice as to how to search the cranking process in somewhat of an in-line trouble-shooting method.
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    Quote Originally Posted by Datamacjoe View Post
    Had this exact same problem with my 89’ 525i. I resolved it by removing the neutral safety switch (car is an automatic) disassembling the switch, and cleaning all contacts with rubbing alcohol. Heavy corrosion on those little strips, and afterwards the car starts IMMEDIATELY, every time.
    If if you want to troubleshoot this, try banging the car into park a few times, then trying to start it. That used to work for me, so if that cures it definitely take a look at the neutral safety switch. (All of this assuming the car is an automatic, if not then it’s a moot point). (Also I just remembered that the car won’t crank with a bad Crank Position Sensor, but I am speaking from experience with an M62)
    Goodluck
    Jul 2018
    Costa Mesa, CA
    1994 BMW 525i
    Thanks will try that. And yes, the car is an automatic.
    Jul 2018
    Costa Mesa, CA
    1994 BMW 525i
    Have another question idea. Is there a way to by-pass everything, as in "hot wire" start the car so that I can work backwards to the fault?
    Apr 2017
    California
    You can jump the starter relay, and I think you can toggle on the starter independently via the diagnostic port. I recommend searching for these two things to get a more detailed set of instructions.
    Jul 2018
    Costa Mesa, CA
    1994 BMW 525i
    Quote Originally Posted by theBMWbeast View Post
    I
    I just tried jumping the starter from under the hood. I believe that the connection to make the starter run and engage the flywheel is the bottom screw connector. When trying that, using a metal rod, I can see a small spark indicating that I am making contact. However, I still get no reaction from the starter. Realizing that the larger screw connector is directly connected to the battery I should have a strong charge going to the starter. Since the spark is small, I think something else must be limiting the amount of electricity coming from the battery. I will be looking to do the same from the diagnostic port.
    Mar 2018
    Brentwood,California, USA
    1994 BMW 525i
    +1 on the neutral safety switch, happened to me about 3 months ago. Do yourself a favor and dont order the non OE replacement. My did dad did that and it doesnt work correctly.
    Feb 2010
    Louisville, KY
    1995 BMW 525i
    May be crank position sensor. I know it cuts the fuel pump off, don t remember but may stop it from cranking too.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Does your car have the security with the chip in the key? I had a 2001 325i and the car would not start because the security chip in the key was toast. No crank at all. I had to bypass the security in order for the car to start. In my car there was a white box under the steering console. I had to cut the blue and black wires and bind them together and voila! The car started.. It would have cost 140.00 to get a new key with a new chip and it had to be programmed with the ECU. I went the ghetto route and cut the wires.
  1. 1994 BMW 525i (E34) Not turning over.
    By jonfernandez305 in forum 1988 - 1996 (E34)
    Last Post: 01-10-2016, 07:59 PM
  2. E34 FS: E34 1994 BMW 525i (Queens, NY)
    By TheTruth in forum E34 Classifieds (closing soon)
    Last Post: 10-22-2013, 10:26 AM
  3. Please help . 1994 bmw 525i engine won't crank
    By wizardof7 in forum 1988 - 1996 (E34)
    Last Post: 02-21-2012, 11:07 PM
  4. E34 NC 1994 BMW 525i E34 Must Go
    By charlessnc in forum 5 series & 6 series
    Last Post: 04-05-2011, 08:30 AM
  5. 1994 BMW 525i E34 M50 engine misfire freeway slight load
    By beammeup12 in forum 1988 - 1996 (E34)
    Last Post: 10-25-2008, 05:15 PM
