Results 1 to 4 of 4
Thread: Ignition Troubles - Rotors
    May 2015
    New Jersey
    1991 BMW 850i
    Hi All, i was wondering if any one has had experience with melted distributor rotors. I bought new coils, distributors, and rotors a few months back. All Bosch.
    One of the rotors Right side seems to have melted through to the camshaft.
    https://www.dropbox.com/sh/kwatvrx9z...8Tsg3susa?dl=0
    Some pics to show the old one and the new one with the hole. Now the hole wasnt that big when i pulled it off. But it was all charred. I used a screw driver to remove the charred bits and that hole is the result.
    Should i just replace the rotor or is it reasonable to think there is an issue with the plug wires? The plugs are fairly new. I had them replaced 30000 miles ago.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Burning is usually due to a poor contact with the rotor - the resistance increases the heat generated at the contact. So, I would hazard a guess that the centre contact is just not connecting properly with the rotor.
    My BMW Repair YouTube Channel
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Sometimes the center pin in the distributor cap gets stuck or breaks, check that, http://i32.photobucket.com/albums/d3...3658c02122.jpg
    plus also check the ignition coils http://www.bimmerforums.com/forum/sh...=ignition+coil
    May 2015
    New Jersey
    1991 BMW 850i
    The distributors are new and both look the same. the center pin is pushed out by the spring.
    It must have just been a defective rotor. I cleaned up one of the old ones and put it back in. Its running fine now.
    I'm gonna keep an eye on it as it took a couple months for that one to burn out.
    I've just never seen a rotor burned through like that before.
  1. ignition trouble
    By edipisswrex in forum 1975 - 1983 (E21)
    Last Post: 08-20-2008, 11:54 AM
  2. Ignition Trouble NEED Help
    By EuroBlood BMw in forum 1991 - 1999 (E36)
    Last Post: 07-14-2008, 02:05 AM
  3. ignition trouble
    By mcanseco in forum 1982 - 1988 (E28)
    Last Post: 04-26-2007, 08:51 AM
  4. Ignition troubles
    By Shiftlink in forum 1976 - 1989 (E24)
    Last Post: 06-16-2006, 02:57 PM
  5. ignition trouble, e30 325i
    By dinknip in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-11-2004, 12:26 PM
