Results 1 to 8 of 8
Thread: Ignition switch replacement
    Jun 2014
    Elizabethton, TN
    1994 750il, 1994 318i
    Hey All,
    I think the ignition switch on my 96 740 just gave up the ghost (steering wheel unlocked, cylinder will not turn with key in it). I know this is a silly question before I ask it, but is this an item that can be easily replaced using a salvage yard cylinder and key? Any help here is appreciated.
    wrestlerdad
    Jun 2014
    Elizabethton, TN
    Oh,I forgot to mention the car is telling me the key is in the ignition when it isn't.
    Greenville, SC
    01 749iM/6 sporty
    Since you're adding the electrical glitch I'd start by removing the electrical part of the switch. Then see if the barrel works.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
    Jun 2014
    Elizabethton, TN
    Quote Originally Posted by 007008 View Post
    Good point. I would rather replace the electrical part it actually seems like less hassle.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Can't go wrong replacing the iggy switch but I don't think it's your issue. I've replaced 2 barrels over the years. One was easy, one not so much as I let it go to long.
    http://www.meeknet.co.uk/E31/Lock/E3...eplacement.htm
    Jun 2014
    Elizabethton, TN
    Quote Originally Posted by Mayorchuck View Post
    I would be interested in your opinion Chuck. Again the ignition cylinder will not turn with the key in it, the steering wheel is not locked and the display tells me the key is in the ignition when it isn't.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    I would pull out the iggy switch to see if it is causing the key not to turn. I don't think it would do that but I would certainly rule it out. At that point you can at least use a screwdriver on the switch to start the car, provided the key is in or near the barrel. If the key is in the right position in the tumbler, you should be able to use Tim's method in the link to remove it.
    Feb 2013
    The Motor City
    1997 750 IL
    Tis the season. I just replaced the barrel because it starting spinning and I did the switch just to get it over with and be new there but the old switch was in great shape except for maybe needing a cleaning.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
  1. Ignition switch replacement question
    By thatracer in forum 1991 - 1999 (E36)
    Last Post: 06-06-2009, 10:25 AM
  2. pics of ignition switch replacement?
    By 5erlvr in forum 1982 - 1988 (E28)
    Last Post: 05-02-2009, 07:05 AM
  3. ignition switch replaced, still won't turn over
    By wv318ic in forum 1992 - 1999 M3 (E36)
    Last Post: 05-07-2008, 09:57 AM
  4. Ignition Switch Replacement
    By bimmerspeed in forum 1996 - 2003 (E39)
    Last Post: 08-08-2007, 01:31 AM
  5. E39 Ignition Switch Replacement Help
    By killcrap in forum 1988 - 1996 (E34)
    Last Post: 01-26-2006, 05:02 AM
