Hey All,
I think the ignition switch on my 96 740 just gave up the ghost (steering wheel unlocked, cylinder will not turn with key in it). I know this is a silly question before I ask it, but is this an item that can be easily replaced using a salvage yard cylinder and key? Any help here is appreciated.
wrestlerdad
Oh,I forgot to mention the car is telling me the key is in the ignition when it isn't.
Since you're adding the electrical glitch I'd start by removing the electrical part of the switch. Then see if the barrel works.
Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
Can't go wrong replacing the iggy switch but I don't think it's your issue. I've replaced 2 barrels over the years. One was easy, one not so much as I let it go to long.
http://www.meeknet.co.uk/E31/Lock/E3...eplacement.htm
I would pull out the iggy switch to see if it is causing the key not to turn. I don't think it would do that but I would certainly rule it out. At that point you can at least use a screwdriver on the switch to start the car, provided the key is in or near the barrel. If the key is in the right position in the tumbler, you should be able to use Tim's method in the link to remove it.
Tis the season. I just replaced the barrel because it starting spinning and I did the switch just to get it over with and be new there but the old switch was in great shape except for maybe needing a cleaning.
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
