Results 1 to 2 of 2
Thread: Passenger seat stuck
    Jul 2010
    Westlake,OH
    1988 BMW 735I
    Passenger seat stuck SOLVED!
    Guys,
    Another problem that I need your input: passenger seat is stuck all the way back such way I cannot get to the bolts in the rear. The seat is not moving, but the seat is powered and the switch works as I was able to to see a current increase when moving the switches. Is there a method to manually move the seat forward in order to access the seat bolts ?
    Thank you,
    Jean
    Well, I went back to the garage, grabbed a glass of red wine and started thinking...a couple of months ago I was able to "unstuck" the sunroof by dismantling the sunroof motor, cleaning the rotor and shoes, all the rods and...it works like a charm!!So, I looked under the front side of the passenger seat and noticed that one can stick a small hex in the end of the seat motor(is the rotor axle end) that is facing the front of the car. I did insert the hex, turned a couple of times, just enough to "break" the oxidation created in between the "shoes" ( I am missing the right term) and the rotor, and when I pushed the button…. the seat started moving!!!. The rest is history...I moved all the way to the front, tilted it, removed it....and did the same with the other motors: all work but the backrest.
    Hop-e this helps,
    Jean
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    you can use a flat 4mm screwdriver to move the seat, see here in one of my posts the attachment https://www.bimmerforums.com/forum/s...orward-or-back
    Avec is using this method
    Pulling electric seats at the junk yard https://www.bimmerforums.com/forum/s...ighlight=seats
  1. passenger seat stuck
    By DesCal in forum 1988 - 1994 (E32)
    Last Post: 06-29-2009, 06:18 AM
  2. Removal of front seats in e36 - Passenger Seat Stuck
    By M3Alpine99 in forum 1991 - 1999 (E36)
    Last Post: 01-15-2009, 11:39 AM
  3. Passenger seat stuck over rear seat bolts :(
    By djames2k in forum 1991 - 1999 (E36)
    Last Post: 05-05-2008, 12:01 PM
  4. Passenger seat stuck...
    By Rocket26 in forum 1991 - 1999 (E36)
    Last Post: 05-03-2008, 06:34 AM
  5. Passenger seat stuck - I need help!
    By Daved in forum 1991 - 1999 (E36)
    Last Post: 02-19-2007, 12:46 PM
