Results 1 to 4 of 4
Thread: Rough running on start up
    Jul 2015
    Newport, Victoria, Austra
    1997 BMW 318iS Coupe
    E36 318iS M44 engine.;
    Car has 215,000 km up and we have had it for 18 years.
    Engine start when it has been sitting overnight results in it running rough for a minute or so.
    After that first start it will start and run ok.
    Idle could probably be a little smoother but it is certainly not what I would call rough.
    Driving performance is equal to what it was when we purchased it.
    New spark plugs, compression in each cylinder is great.
    No sign of a head gasket issue ( I am an old mechanic)
    Any clues folks??
    Jun 2010
    NY
    1997 328i
    Yes can remove and clean the idle control valve. Also smoke test it for vacuum leaks.
    When you're out on the main road floor it a few times, hit redline, helps clean the valves. You can also get a bottle of Royal Purple complete fuel system cleaner.
    Jul 2015
    Idle control valve serviced.
    Quote Originally Posted by Eric93se View Post
    ERIC: I dismantled the ICV then cleaned in ultrasonic cleaner.
    Lots of carbon removed. Will see how it starts up tomorrow morning. Thanks for assisting.
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    Perhaps try/swap the coil pack and high tension leads.. Perhaps those are old? Best to first inspect and then replace the leads. If that doesn't help, then the coil pack.
    When cold and more humid, the chance of misfires/arcing are greater than when slightly warmed up. So it fits the symptoms.
    1997 E36 BMW 323i
    (European) 275k km (171k miles), with following small mods:
  1. 2003 330i Sedan: Rough running when started
    By gtlou in forum 1999 - 2006 (E46)
    Last Post: 01-24-2014, 01:30 PM
  2. Rough running at start up
    By mcallister in forum 1995 - 2001 (E38)
    Last Post: 10-23-2009, 07:15 PM
  3. 745i rough running on start
    By povonline in forum 2002 - 2008 (E65, E66)
    Last Post: 10-08-2008, 12:11 AM
  4. rough running at start up check engine light
    By pfd964 in forum 1991 - 1999 (E36)
    Last Post: 01-06-2008, 12:03 PM
  5. Smoke and rough running on starting
    By stafforj in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-08-2005, 04:49 PM
