Results 1 to 19 of 19
Thread: Supercharging a 540i E39
    Jul 2018
    USA
    2001 540i M-sport
    Just trying to figure out how many miles people got out of a superchargered e39 540i after the SC install.
    Jul 2018
    USA
    2001 540i M-sport
    I recently bought a 540i for 2g's with 173k miles with all original parts. The owner took great care of it but did nothing to it which is why I got it for 2k. I've already replaced alot in it.
    Oil pan gasket (upper and lower)
    Alternator gasket
    Valve cover gasket
    Crank case gasket
    Crank case gasket upper
    Water pump gasket
    Timing chain
    Timing chain guides upper and lower
    Oil chain
    Timing chain tensioner
    Camshaft positioning sensors
    Fan clutch
    Temperature sensor
    So it's in good shape and it was good before beside the plastic laying in the oil pan for who knows how long.
    But I really want more power out of the car and I was looking at installing a SC but I wanted to see what everyone thinks of doing this at 173k miles.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E39 forum
    Jul 2018
    USA
    2001 540i M-sport
    DeWitt, Michigan
    '97 540i/6, '97 328i
    There's nothing inherently wrong with doing that. If the engine is in good condition, it will love (properly done) boost.
    Jul 2018
    USA
    2001 540i M-sport
    Okay that's good to hear. I'm confident in my abilities to install the supercharger myself as all the previous work that's been done was done in my driveway. But as far as the tuning goes I'm pretty lost there.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Perhaps this other recent thread is of interest.
    https://www.bimmerforums.com/forum/s...ger&p=30068802
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    DeWitt, Michigan
    Quote Originally Posted by Walafrid View Post
    Unfortunately, the tuning is really where the "properly" part comes in. Installation is the easy part.
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    6k blower on a 2k car with 180k miles?
    ~2001 540i/6speed~
    Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~
    On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
    Mar 2010
    Quote Originally Posted by topaz540i View Post
    Should we have him fill out the form?
    "Well I'm a really good mechanic and can fab stuff myself no problem and...
    I'm sure I can make a __supercharger/turbo_(pick one) kit for this myself for under $_____,
    like I did on my _________(last fabrication hot rod)...
    I'm planning on using a junkyard ___supercharger/turbo___ (pick one) from a _________ (donor car)...
    really I mean how hard can it be?"
    2003 M3CicM6 TiAg
    Former:
    DeWitt, Michigan
    Sep 2013
    Tx.
    02 bmw 540
    Hey it’s been a while since I played Mad Libs.
    Jul 2011
    hillsborough n j
    I'm sure I can make a __supercharger/turbo_(pick one) kit for this myself for under $10,000,
    like I did on my honda crx si model_(last fabrication hot rod)...
    I'm planning on using a junkyard _roots_supercharger/turbo___ (pick one) from a jaguar_____ (donor car)...
    ~2001 540i/6speed~
    Jul 2018
    USA
    2001 540i M-sport
    Hell yeah I'd buy a new one. I don't see the problem with that, the cars in good shape and I already put 2k into after buying it for 2k. Gotta start somewhere.
    Well I'm a really quick learner did all the stated work above via internet research and youtube videos never working on or owning a BMW before. Im sure a brand new Supercharger for $5-6k on the car is gone be badass. This is my first car so I've never done it before, needless to say I'm excited. Cant be that hard.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    If you interested I am going to sell my Supercharger with 2 options:
    1. VF SC 3.25" full set with pulley (9psi) + Methanol injectors + 440cc Bosch green giants + AFR + AEM never used 320l/h Fuel Pump + EGT sensor = 4000$ (stage 2 tuned ECU from FRANK SMITH for free)
    2. VF SC 3.25" full set with pulley + 330cc injectors = 3000 (additionaly 300 USD for FRANK SMITH stage 2 tune)
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    Jul 2018
    USA
    2001 540i M-sport
    I'm just now reading this I've been looking around while I save up but I'm definitely in the market for one.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Just have a look on 1st option. Almost all of them you will have to buy emideately and some of them after couple of monthes of driving. Becouse you will want a bit more boost and accelarations))))
    1. AEM methinjector costs 450$.
    2. Bosch green giants will cost 450$.
    3. Fuel pump AEM is cost 100$
    4. AEM AFR 175$
    5. EGT 50$ minimum.
    6. TTFS Frank Smith tune 800$.
    7. Small costume pulley 3.25" 100$
    8. Modified bypass valves in intake manifold.
    9. Pressure gauge 50$.
    Etc....
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    I,m running a M62 with a roots blower Jaguar toolman kind of build over a year now can't give mileage as I'm not at home but super happy at the moment.
    Sent from my SM-G930F using Tapatalk
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
    Aug 2017
    SFBayArea
    '03 540iA, '91 850i
    Option 1 sounds intriguing
    '91 850i 6sp CB42360
    '97 840Ci
    '00 528iA sold
    '01 740iA Msport sold
    '01 540iA sold
    '03 540iA M-sport II with e46 m3 SMG style steering wheel with working paddle shifters, Bilstein B8/Eibach sport, Hella euro spec headlights, M5 aftermarket (Umnitza) foldable mirrors (painted body color), M60 IM (custom painted body color 354), powder coated valve covers (@Finish Logic; Concord,CA), Dynavin N7, Bavsound speakers, Cerwin-Vega sub (in spare wheel hub), soundproofed doors, trunk, under rear seat, wheel wells
  1. e36 Supercharged 318ic vs e39 540i/6
    By Cyrix2k in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-31-2008, 04:27 AM
  2. WTB Supercharger for 540i E39
    By benge100 in forum BMW Parts Wanted
    Last Post: 10-15-2007, 12:24 PM
  3. How many Supercharged 540i (E39) here?
    By Jimmy540i.com in forum Forced Induction
    Last Post: 07-15-2007, 04:36 PM
  4. Who sells supercharger chips? 540i e39
    By dannydoo in forum Forced Induction
    Last Post: 07-09-2007, 10:19 AM
  5. Supercharge High mileage 540i E39
    By hhartanto in forum Forced Induction
    Last Post: 10-17-2006, 09:08 PM
