Results 1 to 9 of 9
Thread: 79 320 Overheating issues
    Jul 2018
    Beaverton, Oregon
    1979 320i
    Unhappy 79 320 Overheating issues
    Recently just picked up my car from the auto mechanic to do some general tune-up work I didn't want to take the time to do myself. After getting her back this morning and driving her about a half mile I noticed that the temp gauge was at about 80% so i decided to pull over and take a look under the hood. Car seemed fine, was a bit warm, however, i didn't feel that given the heat the motor was putting off it was anything alarming. At this point though I don't want to risk any damage to the motor.
    I'm looking for advice on the quickest way to identify what the underlying issue could be - auto shop advised that they did a full inspection and that everything seemed to be fine. Checked the oil and coolant levels, tune-up and replaced the breaks and rotors. I let the car sit for an hour or so and turned it back over, after running it down the street and back a few times the temp sky rocket again.
    Bottom line - whats the quickest and most effective way for me to find the underlying issue. All help appreciated.
    I checked additional threads on the forum and found people saying - replace the water pump, ensure its running, check aux fan to ensure its working properly, replace the radiator and everything that comes with it. Rather than putting myself in a position of doing all of that I'd like to just locate the underlying issue. Once again I appreciate the help.
    May 2017
    Los Angeles, CA
    1983 320i
    verify that your water pump and thermostat are in good working order, maybe do a radiator flush too https://www.youtube.com/watch?v=s--5ft5YiHg
    Dec 2013
    Chicagoland area
    EXOTICS
    Test fan operation,
    perform radiator/cooling system pressure test.
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Maybe the belt is slipping and maybe it's also crooked from worn alternator mount bushings.
    Tbd
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Use an Infrared Thermometer to verify your having a cooling issue,really inexpensive now, these car gauges vary on voltage and so forth, aim at the coolant hose not metal.
    Randy
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Hi Randy, the temp gauge needle position is not swayed by voltage variations - assuming all the electrical connections are good! I forget the terminology for this type of electrical style, but has to do with how the gauge's 3rd wire is attached to it.
    Tbd
    Nov 2007
    Cool
    There are tests to confirm that,, As too overheating, it could be a sticky thermostat, clogged radiator-needs a flush,,fan belt too loose and several other items. Its a process of elimination to find the reason for overheating.
    Randy
    Jul 2010
    downingtown,pa
    1978 320i
    if original, probably the radiator. new ones are cheap. i had same issue when i had first purchased my car. new radiator was like night and day. good luck.
    Dec 2015
    phoenix
    1977 bmw 320i
    If it was fine before the mechanic, and he replaced the coolant as part of the tune-up, make sure the air is out of the system. This can cause an overheating condition.
  1. Overheating issue: 1982 320
    By green bean in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-09-2013, 06:38 PM
  2. Newbie 84 318i overheating issue! help!
    By kakarotto in forum 1983 - 1991 (E30)
    Last Post: 01-25-2007, 06:54 AM
  3. Overheating issue
    By ps525i in forum 1996 - 2003 (E39)
    Last Post: 03-30-2005, 01:55 PM
  4. 94 325ic M50 5sp Overheating Issue
    By Lizardkng in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-14-2004, 09:45 PM
  5. Help Overheating Issue.
    By JohnD in forum 1983 - 1991 (E30)
    Last Post: 08-30-2004, 03:16 PM
