Results 1 to 3 of 3
Thread: Determine faulty coil? (M44)
    Jan 2016
    Kyoto
    E92 M3, E36 M3 evo, Z3
    I did a spark plug job a while ago, noticed that when I swapped coil places the car would run really rough (misfire,)
    but go back to normal when I put it back into place. M44 has ignition coil "pack", so it isn't possible to replace only one of them..
    am I in for the whole replacement?
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Do you mean you wired the coil to the wrong plugs? If so, that's why it was running rough - cylinder sparking at the wrong time. Or do you mean something else?
    Jan 2016
    Kyoto
    Quote Originally Posted by BladeRunner919 View Post
    https://www.realoem.com/bmw/enUS/sho...diagId=12_0575
    I think your explanation is spot on. So I numbered the wires (apparently in wrong order, 2-3 was swapped IIRC) before taking them off and the car ran rough when I put back in, so I switched 2-3 and it ran normal.
    Guess I can still use my coil pack!
  1. Faulty coil found
    By JamesJames in forum 1996 - 2003 (E39)
    Last Post: 05-09-2011, 10:49 AM
  2. Z3 E36/7 Wanted: Defective Coil Pack for M44 (1.9L)
    By Monolith in forum Z3,Z4,Z8 Classifieds
    Last Post: 11-21-2008, 08:48 AM
  3. 318 M44 Plug Wires and Coil
    By RobertK in forum Engines, Performance Parts & Software
    Last Post: 03-23-2007, 03:50 PM
  4. slight exhaust manifold leak/faulty fuel injector/faulty coil?
    By KrazyRushin in forum 1992 - 1999 M3 (E36)
    Last Post: 08-09-2005, 08:00 PM
  5. Replies: 2
    Last Post: 04-05-2004, 05:42 PM
