Results 1 to 1 of 1
Thread: different p/n for clips door sill trim panel versions
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    When replacing the door sill trim panel clamps which hold the door sill trim panel/outer kick panel, pay special attention to select the correct clamps. There are different clamps for the different versions outer kicks panels, the clamp thickness is different, do NOT mix, buy the correct ones for your trim panel version. Buy genuine, aftermarket ones could be not correct in dimensions.
    for
    LEFT OUTER KICK PANEL 51718190707, DOOR SILL TRIM PANEL 51718190708 >>>>>only use Clamp NATUR 51718184574 https://www.realoem.com/bmw/enUS/sho...96#51718184574
    for
    LEFT OUTER KICK PANEL M TECHNIC 51712234187 ,RIGHT DOOR SILL TRIM PANEL M TECHNIC 51712234188 >>>>>only use Clamp M TECHNIC 51712234032 https://www.realoem.com/bmw/enUS/sho...diagId=51_2761
    for example on Ebay most sellers do not know the differences for the aftermarket, I searched and found for example one offer OEM: 51711932996, OEM: 51718184574, OEM: 51712234032
    They do not know that these parts are different in dimensions.
  1. WTB 4dr door sill/trim
    By vildea in forum BMW Parts Wanted
    Last Post: 04-01-2006, 08:29 PM
  2. AArrgghh! Different door sill trim on M coupe
    By Curt C in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-24-2005, 01:30 PM
  3. WTB: E36 Motorsport International Door Sill Trim
    By CStricker in forum BMW Parts Wanted
    Last Post: 03-25-2005, 03:14 AM
  4. What does the door sill trim look like on 01 m coupe?
    By beaghost in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-05-2004, 09:11 AM
  5. Help! How to remove door sill trim??
    By BumbleZ in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-30-2003, 08:30 PM
