Results 1 to 4 of 4
Thread: 12V to 13.8V regulator
    Dec 2017
    Israel
    E38 750iL 2001
    Lightbulb 12V to 13.8V regulator
    Hello friends,
    As someone said 9/10 times TRANS FAIL PROG error shows up is due of battery problem.
    To my understanding; the DME and/or the AGS fail/s while starting the engine as the voltage drop below a critical voltage.
    I was thinking if there's a way to keep the modules with steady 13.8V even while starting the giant V12 engine.
    and I came with this:
    https://www.powerstream.com/dc2.htm
    It's a 12v (9v-14) input to 13.8v output regulator, 20A continuous and 50A peak.
    My idea is to connect in-serial the power supply from the battery to the input of the regulator and supply 13.8v via the output directly to the modules.
    Should I give it a try?
    Please share your thoughts :-)
    Greetings,
    Tomer
    Jun 2015
    Racine, WI
    BMW X5 3.0i
    It's an interesting band-aid but it's a band aid that could cause a worse peoglem.
    Usually a low voltage at start problem is caused by either a weak battery or a worn out starter.
    A worn out starter can pull double the current of a properly function one. Image what that means. If it pulls 300 normally (guess) it would pull 600A when worn out.
    Not only does that mean double the internal voltage drop in the battery it means double the voltage drop on the supply cables.
    You could easily go from 11 v to 9v on a fully charged brand new battery. Many people replace their battery and alternator before they determine it's actually the starter at fault the whole time
    Greenville, SC
    01 749iM/6 sporty
    I agree, an electric motor can pull crazy amps toward the end of its life. I once had a blower motor pulling over 20amps.
    The car already has load reduction during the start.
    Hook up a volt meter and see what the voltage drops to.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
    Dec 2017
    Israel
    E38 750iL 2001
    What's the best way to diagnose a starter? The engine starts so the starter isn't dead.
  1. FS: NIB E34 BOSCH 3.0 Bar Fuel Pssure Regulator 13-53-1-715-685
    By peterjk4 in forum Engines, Performance Parts & Software
    Last Post: 10-21-2013, 09:57 AM
  2. 12v regulator ,how too.
    By JEM E39 in forum 1996 - 2003 (E39)
    Last Post: 09-15-2009, 12:08 PM
  3. summary: fuel pressure regulator replacement
    By cek2 in forum 1991 - 1999 (E36)
    Last Post: 09-22-2003, 10:18 AM
  4. Need a 12V switched (with key) power source - ideas?
    By Seedster in forum 1991 - 1999 (E36)
    Last Post: 07-12-2001, 08:44 AM
  5. help: Fuel Pressure Regulator or Larger Injectors
    By M3RCR in forum 1992 - 1999 M3 (E36)
    Last Post: 05-01-2001, 09:30 AM
