Results 1 to 16 of 16
Thread: Junk Yard find questions
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    My e34 is a 1995 525i
    Found another same car in the local JY. Questions
    1. My cluster has been having problems displaying the correct fuel level and sometimes speedo, so the capacitors are fried. Can I remove cluster from junker and plug and play or is there coding and security issues?
    2. The JY has remote key enter module. Take that plus the wiring but then how do you get a remote key and how to make it work?
    CT
    '94 530iT LSx/T56
    RI
    2008 M5, 1995 540i
    Factory alpine remotes cost a fortune for the alarm, unless you have one already. I wish I kept some old ones I had, want to add the factory alarm to my car but not paying $150+ for a remote. The alarm modules are cheap on ebay.
    Anyone know of an aftermarket generic remote that can work?
    Current Cars
    2008 BMW M5 6 spd
    1995 BMW 540i 6 Spd
    2016 M4 Cabrio 6 spd
    2017 X5 35d MSport
    2017 i3 94ah Rex
    Former Cars
    2013 135i MSport Cabrio DCT
    2012 BMW X5 35d Sport
    2000 BMW Z3 2.8 Roadster MSport Impala Brown
    1992 BMW 535i 5 Spd
    2011 BMW X3 2.8i MSport Alpine White
    1995 BMW 530iA Artic Silver
    1986 BMW 635CSi Bronze Mettalic
    2009 Dodge Ram 2500
    moroza's Avatar
    BFE
    E34T
    Dec 2011
    Lancaster CA
    You guys are awesome. Thanks. So I just need to find a key fob. The e39 I was tearing into last week had a key under the front seat, maybe I’ll get lucky with the e34.
    May 2017
    Australia
    1989 535i
    Quote Originally Posted by bagekko View Post
    Aftermarket generic remotes can be programmed to work according to a few automotive locksmiths I've talked to about the E34. E34s after 1991 use radio like every other car of today but early ones used IR, which has absolutely no aftermarket support. I've got a stock system on my car but the PO lost the remote and I can't track down another one and they're not made anymore.
    As for programming the remote, there should be a guide to it in the manual. It's something simple like having the key in ignition 2 and holding the lock button.
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    Just make sure the color of the back cover of your cluster is the same as the one from the junkyard. It should be blue. Just swap coding plugs.
    CT
    '94 530iT LSx/T56
    Quote Originally Posted by kouks View Post
    PM me about a keyless remote. I should have something on hand for you.
    -Alex
    Mar 2012
    Baltimore, Maryland
    2016 640i, 1990 535iM
    For alarm. I found the Viper system to be quite nice.
    2016 640i Coupe'
    1990 Bmw 535i Turbo 600whp
    1999 740iL: Sold
    1997 740i: Crashed and Parted
    1988 535i: Crashed and Parted
    1988 528e: Crashed and parted
    IG- @Rogetta_Stone
    NW suburban Chicago
    hiss by my window
    Nobody steals E34s, guys.
    ANY car that comes into my possession with an aftermarket alarm gets it removed pronto. I've yet to see a decent installation of one. Nothing but problems lurking if you ask me.
    Kouks, I have a '95 cluster with cracked cover and missing LCD display I was saving for some reason. Yours for the cost to ship it should you want it. PM if so.
    Cheers,
    Dec 2011
    Lancaster CA
    I’m just looking to get her a remote so she can join the modern age and also have an alarm if she needs to activate it.
    Ross, I’ll try the blue backed cluster I got from the JY and let you know if I need yours or not.
    AHenry, pm’d
    Dec 2011
    Lancaster CA
    Cluster installed and works great, swapped code module, and yes it had the same baby blue back on it.
    Remote Entry and Alarm system installed, still looking for key fob, not found in JY. Asked at Autozone if I could use a generic remote, they looked it up on their system and told me to go to the dealer.
    May 2017
    Australia
    1989 535i
    Have a look on eBay for a remote, it'll be a lot cheaper than going to the dealer and programming isn't too difficult. I've found plenty of remotes for the later E34s for decent prices.
    Ross, what about installing aftermarket remote central locking? I have the original IR system in my car but no remote. A used IR remote is almost $400 and I'd rather have a cheaper system that will be guaranteed to work since I have no idea if the IR stuff would still function.
    May 2017
    Perth, Western Australia
    some
    Quote Originally Posted by CarterH View Post
    Alarm systems usually don't come with relays for central locking. Sure they have a remote and the alarm has triggers for central locking, but the alarm door lock output is low current so you or an installer has to add and wire the relays for the locking function separately anyway.
    I had to rewire my old cyclops alarm (made by dynamco) a while back and the relays were just added generic ones cable tied and stuffed into the kick panel, it wasn't part of the alarm (though the alarm remote triggered lock/unlock).
    You can get separate central locking kits but they come with actuators which you don't really need (unless you want spares).
    You can get just the remote module and relays that do central looking from mongoose https://mongoose.com.au/remote-centr...35-detail.html but no idea how much they cost (might be cheaper buying the kit with actuators from overseas, or might cost the same as getting a full dynamco alarm anyway - here in WA we have to have an immobilzer by law so may as well make it an alarm and central locking feature too).
    E: https://www.ebay.com.au/itm/Mongoose...-/152297567846
    Wiring is pretty simple, even my alarm installers didn't stuff that part up. There's 12V under the dash to power it, and 2 wires needed to run for lock/unlock at the drivers kick panel/floor side wiring. I doubt an installer would charge more than $140 to fit. No messing with immoblizer/door switches/horn required, though you may want to hook up to indicators so you can see them flashing when locking/unlocking but that's a simple splice that I've seen done on my own car. Rather than buy from ebay just look up a local mongoose dealer and get a price for supply and fitting price (just keep that ebay price in mind so you know you're not getting ripped off). No point buying a mongoose system and finding later there's no installer of that brand local to you - if no dealers then see if there's a cyclops/dynamco equivalent product for a similar price)
    NW suburban Chicago
    hiss by my window
    I have no idea about this. Any car that comes into my hands with aftermarket stuff has it removed pronto. Maybe they aren't all bad but I've yet to see an installation I could be proud of.
    I have a few of the factory alarm/remote modules gathered over the years, Alpine units I think, but no fobs I can think of. Not sure if IR or radio.????
    If these are of use to anyone feel free to send a message.
    May 2017
    Australia
    1989 535i
    Mine came with an aftermarket system which worked for a few months but crapped out pretty badly to the point that I'd have to unhook the battery to start the car. I've since had it removed which was a really quick job by he auto electrician and it was all located under the dash. I'm wondering a little if that will complicate things.
    I'd love to use the stock system but I think they started using radio after 1991 or 1992 so mine being an 89 build date, I'm out of luck for getting a new remote.
  1. love good junk yard finds.
    By bmwlover0725 in forum 1991 - 1999 (E36)
    Last Post: 09-23-2009, 11:43 PM
  2. Junk Yard Find - Philadelphia
    By cis8vgti in forum 1975 - 1983 (E21)
    Last Post: 09-01-2009, 06:27 PM
  3. junk yard find
    By LouieD in forum 1988 - 1996 (E34)
    Last Post: 07-03-2009, 02:33 PM
  4. Sick Junk Yard Find
    By UmmYeahOk in forum 1983 - 1991 (E30)
    Last Post: 11-12-2007, 07:53 PM
  5. junk yard find
    By e30luv318i in forum 1983 - 1991 (E30)
    Last Post: 01-25-2007, 12:31 AM
