The car is fast, but, if I hammer the pedal, it delays a good second...prior owner I am told put in new coils and plugs.
Is it automatic? Maybe it's shifting down? Are you lugging it or is it up in RPM when you "hammer the pedal"?
I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
The law does NOT determine "right" from "wrong". They are unrelated.
If you put cheap parts on your car, you will soon have a cheap parts car.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I purchased the bmw 1.4 scanner, see no engine codes. Have no CEL. Have not driven others. Prob not a full second delay, but 1/2...It's just not instant. Checked the cables to the throttle body, tight. New K&N filter when I got it. Plugs look great, car overall seems very well cared for. Engine clean inside (did valve cover gaskets)...Cleaned MAF also.
Again, auto or manual? Miles? Where is Rockford?
One of his other post said 190K miles and said Michigan.
Rockford?? He could be using a VPN (which is OK) as the IP doesn't jive with Rockford.
Rockford,MI...
Automatic, sorry. It's not downshift delay at all, it's just a big delay.
I would check the fuel pressure
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
FWIW - I've seen a similar problem when I was Autocrossing my 528i. (Also an automatic.) When coming out of sharp turns and flooring the throttle, there was a significant delay before any RPM's would build. In my case, changing the shift pattern from D to 3 or 2 seemed to alleviate a good portion of the delay. Not perfect, but better.
James
