Results 1 to 11 of 11
Thread: 1998 540I v8 not as quick off the line as it should be
    May 2018
    Rockford
    The car is fast, but, if I hammer the pedal, it delays a good second...prior owner I am told put in new coils and plugs.
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    Is it automatic? Maybe it's shifting down? Are you lugging it or is it up in RPM when you "hammer the pedal"?
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    San Jose, CA
    1997 BMW 540i 6 speed
    Quote Originally Posted by Eriklane View Post
    Have you driven other '98 540s to compare?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by Santaclaus4 View Post
    Is it automatic?
    Essential question.
    Also, are there any engine codes.
    Vac leaks and high trims can cause weird accel issues but you should see if there are codes. No the fact you don't have a CEL / SES doesn't mean that you don't have codes.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    May 2018
    Rockford
    I purchased the bmw 1.4 scanner, see no engine codes. Have no CEL. Have not driven others. Prob not a full second delay, but 1/2...It's just not instant. Checked the cables to the throttle body, tight. New K&N filter when I got it. Plugs look great, car overall seems very well cared for. Engine clean inside (did valve cover gaskets)...Cleaned MAF also.
    San Jose, CA
    Again, auto or manual? Miles? Where is Rockford?
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    One of his other post said 190K miles and said Michigan.
    Rockford?? He could be using a VPN (which is OK) as the IP doesn't jive with Rockford.
    May 2018
    Rockford
    Rockford,MI...
    Automatic, sorry. It's not downshift delay at all, it's just a big delay.
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    I would check the fuel pressure
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Philadelphia, PA
    2005 M3 & 2004 330i
    Rockford,MI...
    Can you take a video?
    Arklahoma
    '94 325i, '97 528i
    FWIW - I've seen a similar problem when I was Autocrossing my 528i. (Also an automatic.) When coming out of sharp turns and flooring the throttle, there was a significant delay before any RPM's would build. In my case, changing the shift pattern from D to 3 or 2 seemed to alleviate a good portion of the delay. Not perfect, but better.
    James
  1. 1998 540i priced to sell quickly $3,900.00
    By HiLandR in forum 5 series & 6 series
    Last Post: 09-23-2014, 12:29 PM
  2. 1998 540i overheating, aux fan not engaging
    By neonphire8604 in forum 1996 - 2003 (E39)
    Last Post: 07-24-2013, 07:08 PM
  3. 1998 BMW 540i Will not start! HELP!!!
    By DMANN2 in forum 1996 - 2003 (E39)
    Last Post: 10-25-2011, 06:28 AM
  4. 1998 540i v8 multiple missfire
    By IPM in forum 1996 - 2003 (E39)
    Last Post: 05-12-2011, 10:18 PM
  5. 1998 540i Sport for sale...
    By SJTrance in forum BMW Cars For Sale / Wanted
    Last Post: 05-30-2003, 12:50 PM
