Results 1 to 5 of 5
Thread: 91 or 99 Degree Fan Switch for early 323i
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    The #22 temp switch in this diagram does not work in my car, preventing the electric fan from turning on.
    There is a 91 or 99 degree Celsius switch listed for this part, which one should I pick for an early 323i with a stock cooling system (no mechanical fan) and no A/C? I'm leaning towards the 91 just to play it safe.
    england
    rhd 320i 1977..
    my first 6 cylinder e21(1977) had two temp switches for a twin speed fan and resistor for the low speed which had failed along with the higher speed temp switch .The connections on the switches were different sizes too. if you remove the switch and clean the flat sides of the nut on the switch the operating temp of the switch is stamped on the side..try bypassing the temp switch to make sure the fan works before buying a temp switch as it could be the resistor playing up...
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Quote Originally Posted by english320i View Post
    Thanks for the info. I've already checked the fan/resistor and bypassed the top temp switch to confirm. I was wondering if the other one was a temp sensor or another fan switch.
    Do you have any idea if the two #22 part numbers correspond to each switch, or is the lower one missing from the diagram?
    england
    rhd 320i 1977..
    both temp switches fitted in the aluminium pipe fitting on the left side of the radiator are for the electric fan. The 91cel is connected to the resistor for slow speed fan and if the engine gets hotter the 99cel switch kicks in the fan at full speed..
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Thanks for the help. I replaced both switches today and the fan works properly now.
  1. Aux Fan Switch 91/99 vs 80/88
    By SergeBMW in forum 1988 - 1994 (E32)
    Last Post: 11-02-2015, 01:34 PM
  2. SPAL 195 Degree Fan Switch
    By bubbajan21 in forum Engines, Performance Parts & Software
    Last Post: 01-25-2013, 07:15 PM
  3. E36 FS: 80/88 degree fan switch 61318361787
    By Madjap in forum Engines, Performance Parts & Software
    Last Post: 04-03-2012, 03:43 PM
  4. brand new 91/99 C fan switch OBD1
    By 98BMW323is in forum Engines, Performance Parts & Software
    Last Post: 03-05-2008, 05:18 PM
  5. Fan switch and 80 degree tstat a must?
    By SR20Fastback in forum 1991 - 1999 (E36)
    Last Post: 06-27-2003, 03:46 PM
