Ok I have a 98 e36 328is. Was just driving down road and car drops to idle. The gas pedal has very little tension and won't work. Now I'm stuck on side of road in Knoxville TN. First, any ideas and second anyone here know where I could tow to to be fixed in the area?
Does it rev normally if you manually open the throttle body from under the hood? Maybe the clip broke that holds the cable to the throttle body arm. It is under the throttle body.
'94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
'93 325is Coupe, Schwarz, work beater 299k
'89 325i Vert, Alpine White: 5spd swapped. Sold
'04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
'05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
'85 Toyota LandCruiser: Lifted, gas hog. 205k
You may be able to get it together enough to get home with a zip tie to hold the cable to the arm. Here is a screenshot from realoem. That should give you an idea of what things could possibly break.
