Results 1 to 2 of 2
Thread: Fault code 2a90 exhaust camshaft, tooth offset to crank shaft
    Jul 2018
    Oman
    E46 330ci e60 540
    Hello guy i have this problem in my e60 540i 2007
    I changed the vanos sensor
    I checked the timing and it ok
    I changed the adjustment unit for exhaust both side
    I change four camshaft sensors and crank sensor
    And still same fault
    Dose anyone know what the problem? Or he had it before?
    Sep 2018
    TN
    2008 535xi, 2001 330ci
    I'm assuming it means exhaust camshaft vs tooth offset to crankshaft, like it thinks the crank sensor vs exhaust cam sensor are not in sync? That is a new one I have not seen.
  1. camshaft sensor fault code
    By nvillarin in forum 1996 - 2003 (E39)
    Last Post: 07-06-2008, 10:32 PM
  2. Camshaft Position Sensor repl, still shows fault code
    By jeffsnavely in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-14-2006, 07:36 PM
  3. Fault Code: "Camshaft Position Sensor"
    By e39driver in forum 1996 - 2003 (E39)
    Last Post: 11-11-2006, 04:55 PM
  4. Fault Code after M3 Exhaust Install?
    By Baykah in forum 1991 - 1999 (E36)
    Last Post: 01-02-2006, 07:05 PM
  5. Camshaft Sensor Fault Code
    By NicolasW in forum 1992 - 1999 M3 (E36)
    Last Post: 09-08-2001, 02:48 PM
