Results 1 to 6 of 6
Thread: HELP!! Servicing E30 rear outer CV joint
    Jul 2018
    Atlanta
    1992 e30 318i vert
    Hi. I'd like to change the bearing in the rear OUTER CV joint of my E30. Can anyone tell me how to open it up and get inside? I saw a post somewhere with info on this, but it was old, the pics didn't work and I didn't really understand the instructions. Thanks
    CANTON, OHIO
    TRIUMPH tr250,tr6, bmw 325i
    The last time I replaced that cv joint it was very difficult to seperate the axle parts and I think your better off replacing the whole axle with both cv joints as a unit.
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    This is probably what you are looking for http://e30performance.info/viewtopic.php?t=2026
    I tried this and was not successful. I couldn't get it to seal properly, I guess I buggered up the cups. Ended up replacing the axles. Interesting learning experience tho...as my entire E30 project has been!
    2004 525i Sport, Manual - 1985 325E Coupe Manual
    Jul 2018
    Atlanta
    1992 e30 318i vert
    Tomstin - thanks for the post. That is about the inner joint, though. It only talks about putting the boot on the outer joint. I'll keep looking
    May 2005
    Houston, TX.
    15 X5, 02 330i, 09 MiniS
    The dust shield is crimped onto the outer CV outside race and is not really able to be removed without destroying it. Furthermore its not readily available to go out and purchase, and even if you could crimping it again would be an issue.
    Wash the old grease out with solvent and a brush until its as clean as humanly possible and then repack it before installing a new boot.
    Tenured Automotive Service Professional - Avid BMW Enthusiast
    Jul 2018
    Atlanta
    1992 e30 318i vert
    Thanks Stuck (sorry - no umlaut on my keyboard). I have decided to simply buy new half axles.
  1. Help: Z3M Outer CV Joint Question
    By kojohns in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-13-2013, 08:48 AM
  2. What if rear axle (cv joint) outer boot damaged?
    By theonerainbow in forum 1995 - 2001 (E38)
    Last Post: 04-03-2011, 12:08 PM
  3. need help, install e30 rear wheel bearings, you make $$$$
    By jeremye30 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 10-19-2007, 11:37 AM
  4. outer CV joint help
    By jmitro in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2006, 11:08 PM
  5. E36ers, anyone rebuild the rear outer CVs?
    By mcclaskz in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-03-2005, 05:51 PM
