Results 1 to 7 of 7
Thread: Euro Cluster Engine Light?
    Oct 2016
    Melbourne, Victoria, Aust
    1993 E36 318is
    Done a small amount of research on my 1992 318is, trying to troubleshoot some random problems with the car. Was trying to do the "Stomp" test but with no luck at all. Did some digging into it and found that apparently European models (I live in Australia) didn't come with the engine light wired in. Took out my cluster and checked for a bulb in the correct position (there was a globe there). Tried swapping globes to see if it was blown, the globe did in fact work in other sockets. So i deduced that its something to do with the cluster. Found some people disusing the same issue, apparently you can get the socket to work properly. Is this easy to wire up, seen a few people say you can do it but not 100% confident of my abilities nor if the process is worth my time.
    Cheers Ben
    Oct 2013
    The Netherlands
    2011 E90 325xi
    So how do you know the check engine light should be turned on?
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    A clue might be does the check engine light turn on for a second when you turn the key to run and then turn off? That is a self test.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    The Netherlands
    DE-spec E36 328i/M3 cab
    There's nothing to check. EU models don't have a "Check Engine" light. It has Check Control light that comes on with OBC prio 1 and 2 warnings. Where on 1 it can't be turned off, on 2 it goes off when you hit the check button.
    IG:
    Apr 2014
    UK
    1995 BMW 328
    This is correct, there is no light.
    However, the Euro 325 has the capability and is just missing the bulb and the wire from the X20 to the bulb.
    You can therefore do the stomp test on a euro E36 325 if you either add the above or stab a test lamp (it is switched earth IIRC) into the X20 at the correct wire.
    IF the US 318 had the engine warning lamp you might be able to get it with a flash but you could also be missing extra lambda sensors and be in a world of pain
    OP if you have a right hand Euro car you would be better off on the .co.uk site
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Oct 2016
    1993 E36 318is
    Yeah light doesnt turn on at all even when turning on the car. This is what made me suss in the first place. Car does run but pretty poorly. bought it for next to nothing and am trying to get it up to scratch. Not a big deal but was just wondering if it was something you can change or not. Can you swapm clusters to a US spec on or is it more complicated then that?
    Apr 2014
    UK
    1995 BMW 328
    ^ Already given you all the info you need. How would swapping a cluster magically connect the cluster to the ECU and magically install firmware on the ECU to operate a light?
    If you want to see all the bulbs light up for no good reason do the "cluster test" (google or you tube)
  1. Euro Cluster Check Engine Light
    By ishcan in forum 1988 - 1996 (E34)
    Last Post: 07-29-2016, 03:46 AM
  2. E36 OBD1 wiring M3 325i Euro Cluster Engine 5spd Swap Seats Trim LTW Koni
    By enginesong in forum Whole Parts Cars
    Last Post: 04-09-2011, 10:50 PM
  3. NO CHECK ENGINE LIGHT ON EURO's
    By Tbellamy in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 10-13-2009, 09:31 PM
  4. cluster engine light
    By HunkaTunka in forum 1983 - 1991 (E30)
    Last Post: 08-04-2009, 01:59 PM
  5. Some instrument cluster warning lights dont go OFF until engine starts
    By blackrider in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-30-2009, 12:43 PM
