Results 1 to 15 of 15
Thread: Side View Mirror Fix
    Jul 2018
    Bluff City, TN
    1998 Z3 Roadster, 2.8L
    Can anyone point me in the direction for a link to where I can purchase the fix for the wobbly side mirrors on a 98 Z3? I've searched but cant find.
    Thanks in advance!
    Nov 2009
    Herndon, VA
    99 z3 2.8L
    How does it wobble? The glass or the whole mirror housing?
    Two bolts hold the mirror base to the door shell. They could just be loose.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    The mirror is a complicated hazard. I thought I had a rattle in my driver door when closing it, but traced it to the innards of the mirror. I am very hesitant to go into that mirror over a mere rattle.
    https://www.bimmerfest.com/forums/sh...9&postcount=29
    https://www.bimmerforums.com/forum/s...6#post26854646
    http://forums.bimmerforums.com/forum...mirror+removal
    https://www.youtube.com/watch?v=0xZSQAFJIP0
    For replacing a mirror, see:
    https://www.ebay.com/itm/152055689014
    BMW MOA 696, BMW CCA 1405
    Oct 2013
    Rock Hill, SC
    2000 BMW M Roadster
    I've never heard of this, but I guess the Z3 mirrors are prone to failure due to aluminum corrosion:
    https://www.youtube.com/watch?v=0xZSQAFJIP0&t=346s
    Oct 2012
    Louisville, KY
    That's the same video as in Post #3.
    May 2013
    USA
    2001 Z3 3.0/5 roadster
    If you're talking about the glass shaking, I was never able to come up with a fix other than pressing a small piece of tacky putty in the top right corner (drivers side) of the glass to housing space.
    Jul 2018
    Bluff City, TN
    Not just the glass....it's the entire housing, glass and all on both sides. I believe I read somewhere that they are prone to failure due to the corrosion of the internals. Somewhere along the way I saw a video/website that had the "fix" for the internals that were replacing the original internals with a plastic like structure. I made sure my bases were tight, so all is well on that front. My biggest fear is having to replace the entire mirror on both sides, which is crazy costly.....
    May 2013
    USA
    My passenger side is perfectly fine but with the driver's side I went as far as depressing the sheet metal under the rear of the base to get a firmer lock down to the door. No improvement at all from that or angle shaving inside the base. I gave up and tacked the corner for an acceptably small amount of shake. I've read of internal spring failure of course but that doesn't account in my case and spending on replacement parts was too risky for me.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    OP, I think this may be what you're talking about: http://www.spiegel-z3.de/die_reparatur.html
    Or in English: https://x8r.co.uk/bmw-z3-e36-outside...dle-repair-fix
    Aug 2013
    Bay Area, CA
    '99 Z3MC, '07 Z4 3.0si
    Quote Originally Posted by BladeRunner919 View Post
    Shoot. That's excellent. Really too bad they don't have a version for the M mirrors.
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by kungfooren View Post
    M mirrors shouldn't corrode since they are only driven in perfect weather and are stored indoors under cover at all other times.
    Oct 2018
    Franklin,TN
    1997 Z3 roadster
    Both mirrors on my Z3 were broken, that is the aluminum frame had broken. I purchased a set of the replacement frames listed above on Ebay and they worked very well. The video was easy to follow and changing the bases was very simple. The only down side was the bases are black and the original bases were painted to match the cars color. The bases being black actually looks ok but will probably get painted when I do some touchup work.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Quote Originally Posted by Mr Bingley View Post
    What's that you say?
    Nathan in Denver
    Tallahassee
    1998 Z3 M Roadster.
    Quote Originally Posted by s8ilver View Post
    Lol. Same here. Daily driver.
    Aug 2015
    Denver, CO
    Quote Originally Posted by magnetchief View Post
    That photo was from the 1st month I had the car back in 2015. We had a freak snow storm that day. It was 60 and sunny a couple hours earlier. In fact that was the only time I got caught in the M in snow, and since it was a Hawaii car, it was the first time the car ever saw snow. I had PO's baldish summer rubber on and an interesting drive home that day.
    Nathan in Denver
  1. Need To Fix My Power Side View Mirrors
    By Cha Ching in forum 1983 - 1991 (E30)
    Last Post: 01-30-2009, 12:14 AM
  2. How do you disable to automatic side view mirror adjustment?
    By Cheuk in Seoul in forum 2001 - 2006 M3 (E46)
    Last Post: 02-21-2003, 03:42 AM
  3. driver side , side view mirror
    By Dj Waffelz in forum BMW Parts For Sale
    Last Post: 01-02-2003, 02:43 PM
  4. PICS! 80MPH, big ass chuck of retread, side view mirror, and impact
    By Madd96///M3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-29-2002, 01:16 PM
  5. M3 Side view mirrors questions
    By umnitza in forum 1992 - 1999 M3 (E36)
    Last Post: 08-19-2002, 06:21 PM
