Results 1 to 16 of 16
Thread: Engine Transmission removal
    Jul 2016
    South Carolina
    1986 325e 2001 330ci
    86 325E with manual transmision
    I am about to pull the engine / transmission assembly out and have a question about the shifter assembly.
    Can I leave it on the transmission and pull the shifter arm or do I need to disengage the bitch clip and pull the entire assembly? I am hoping there is a way to take off the shifter arm and worry about the bitch clip after the unit is out and on the floor.
    any help appreciated
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    we always pop off that clip and separate the arm from the shifter
    No e30s again.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by superj View Post
    +1
    Jul 2016
    South Carolina
    The reason I am asking
    There is no way BMW puts that clip on after they install the engine transmission assembly. So it stands to reason it was on there when installed. It also stands to reason that the car rolled down the line, therefore the suspension was already installed preventing them from putting the engine and transmission in from the bottom straight up. So my thought was that they tilted it and guided it in.
    My question now is, is this a manual transmission that these guys pulled out and if so is that the shifter? You can just jump to 2:45 in the video
    https://www.youtube.com/watch?v=xL8VgToCPNs&t=3s
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    I'm pretty sure the engine, transmission, front subframe and suspension are installed as a complete assembly.
    "Howdy, Folks!"
    Jul 2016
    South Carolina
    Quote Originally Posted by richardodn View Post
    Well there goes that theory. I will figure out how to get that clip off. I just can't actually "see" the clip is my problem
    Dec 2005
    No e30s, again :(
    you are talking about the one right under the shifter, right? the one right under the shifter can just be pushed off with a screw driver or plier but the one at the end nearest the transmission sucks. you can pop it off also but it is a blind push. I leave the one and just pop off the shifter clip and leave the linkage attached the transmission
    No e30s again.
    Jul 2016
    South Carolina
    If that is the only one I have to take off I'm golden, that one is easy. I'm talking about the one past the gubilo. I can't quite figure out how to get to that one. I'm almost at the point I can lean the assembly back and was hoping I could reach it then. Or better yet do I just need to take the one off, the easy one?
    Dec 2005
    No e30s, again :(
    that one, its tough. I leave that one alone and just wait till its out of the car if I need to mess with it
    No e30s again.
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    I removed a manual transmission and engine from a 325e also. Once I pulled the shifter mechanism off and it was fairly simple after that.
    Use a hook to dislodge the clip - such as the tool to remove exhaust donuts - and pull from the back of the transmission and it should pop right off.
    Jul 2016
    South Carolina
    Quote Originally Posted by 95BMWIC View Post
    soo...are you saying I only need to remove the ONE clip from that rear that is easy to remove???
    Nov 2009
    Des Moines, IA
    See my post on this #18
    https://www.bimmerforums.com/forum/s...nsmission+clip
    The main hangup for me was that darn clip also.. but I was able to pop the clip and remove the engine and transmission together.
    Nov 2009
    Des Moines, IA
    Also - Good pics here - See post #24
    https://www.bimmerforums.com/forum/s...4#post16845764
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    IF you drop the subframe/engine/transmission together, then all you need to do is unbolt the rear carrier bushing, and free up the rubber shifter boot/grommet. (Remove the knob/shift boot, of course.)
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    Regina, Sask, Canada
    82 320i 89 325i
    there is a diy using a rad hose pick that works. i substitute the rad hose pick for a hammer in style storage hook and it pops first try every time.
    DIY: Undo the bitch clip the easy way
    Jul 2016
    South Carolina
    Quote Originally Posted by 82eye View Post
    Thanks just what I needed. Hoping to find the time to pull it this week
  1. engine/transmission removal questions.
    By inkacola in forum 1988 - 1996 (E34)
    Last Post: 03-11-2013, 10:06 AM
  2. engine/transmission removal questions.
    Last Post: 03-11-2013, 12:52 AM
  3. E24 engine and transmission removal tips needed
    By OregonMTB in forum 1976 - 1989 (E24)
    Last Post: 10-05-2012, 09:44 PM
  4. Engine & Transmission Removal Question
    By etamax in forum 1999 - 2006 (E46)
    Last Post: 11-02-2010, 09:28 PM
  5. Transmission removal, where to get engine brace
    By mrhmmhmm in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-06-2002, 12:21 AM
