Results 1 to 9 of 9
Thread: GPS camera with accelerometer and OBD2 input/overlay?
    Feb 2018
    San Diego, CA
    2001 Z3 Coupe
    For the track or Sunday drives, is there a system which can overlay ODB2 information out there which is worthwhile? The overlay doesn't have to show info live, it can be on the recording. Maybe one with GPS and/or accelerometer? I have an Android phone with a good camera (LG G3).
    I'm reticent to use off-branded cheap stuff because the software and ease-of-use will make or break this, and they'll never update their glitchy software. I'm thinking under $300 if possible. I assume something connected to my phone may be the cheapest, best way, but I'm a newby about this. In a perfect world I could transfer it to a motorcycle (no OBD2) and record from that, too--but this is low priority.
    Aug 2013
    1999 BMW M3 Coupe
    For track, I use Harry's Lap Timer. It works with OBD2 info and also with either your phone's GPS or a more accurate external GPS module. You can use either the phone's camera, or just use the phone to collect data and sync it with video recorded by gopros or whatever. It has maps of all the tracks so it tracks corner speeds and things like that in addition to lap times. There's a few different versions at different price points depending on which features you need.
    Mar 2006
    Menlo Park, CA
    95 M3 & Legacy Manwagon
    Quote Originally Posted by Henway View Post
    Garmin VIRB advertises this feature-- GPS + accel + OBD2. I think one of the GoPros will also. Both are in the ~$400 range new if I'm remembering right, but don't quote me on the cost.
    "Fear disturbs your concentration" -Sabine Schmit
    1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
    1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
    2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
    Vancouver, BC Ca
    1993 325is
    There's also Solostorm from Petrel Data:
    https://www.petreldata.com/
    Feb 2018
    San Diego, CA
    2001 Z3 Coupe
    It seems as though $400 is the base price for any decent system after ODB2 and GPS and software are included. Though it seems a la carte could be cheaper, a dedicated system may be best.
    Sep 2013
    Perth, Australia
    2011 BMW 135i
    Quote Originally Posted by Bimmerman535i View Post
    I have a Garmin Virb, it works OK but the GPS is a bit slow and sometimes inaccurate. I also can't get it to connect to my ODB dongles.
    example
    I would recommend Harry's Lap Timer. It will connect to ODB dongles no problem, and with an external GPS receiver (I use a Dual XGPS160) it is very accurate.
    example
    Sep 2008
    NS, Canada
    E36 M3
    I would avoid the Virb Ultra 30. I'm pretty disappointed with mine.
    1) This year my GPS just...doesn't work right. In 2017 it was OK. Track map was generally accurate and laptimes were within 0.1 to 0.2. Although I did have the start/finish drift on my once. But this year it just plain doesn't work anymore. Trace map looks like a 3 year old doodled the track map 15 times. Speeds are all wrong and you can see on the trace when it just lost connection. Had issues all year no matter what the sky conditions are.
    2) OBD2 connectivity is super flaky. I don't have it in my racecar, but we tried it in both my E36 autoX car and old 7th gen civic rallyX car. It basically worked at random for short bursts of time.
    3) Camera mic couldn't handle the racecar noise/vibrations and has noticable sound quality issues now.
    The sad part is the virb editing software is incredibly easy to use. And when the GPS did work is was decent:
    https://www.youtube.com/watch?v=CsEQqe90hQs
    I plan to switch to an AIM solo (since I actually want data) and just keep using the camera with the GPS disabled.
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    I did some digging into the Garmin Virb Ultra 30. The results were disappointing. It appears that it can receive a GPS signal at 10hz but it can only write at 1hz to the .fit data file. Most phones receive GPS at 1hz so there really isn't a data advantage there.
    Thread with more info here: https://www.bimmerforums.com/forum/s...ht=garmin+virb
    Also, I stopped using Harry's Lap Timer because it's sorta buggy. I switched to TrackAddict and it has worked well thus far.
    May 2015
    Easton, PA
    1996 BMW 328is
    I've tried this a couple of ways. There's software called RaceRender, which will overlay any data set on to your video, much like Harry's does, but you can do it on your computer instead of your phone, which I prefer. I use a DIY external GPS combined with harrys and a gopro...the external gps is much faster than internal iphone (10hz vs 1hz) and will smooth out the curves.
    Unless I'm completely mistaken, the OBD issue is the refresh rate of the OBD signal from the car, not the reader (I'm speaking from e36 experience). It really is useless for what we're looking for. The E36 OBD transmits at approx 1hz, and the more bits of info you're looking to capture, the worse it will be. If you're on a more modern platform, there are data systems (like AIM SOLOdl) that can get direct CAN data, which will be much faster. As far as I have found, the only other option is to add your own sensors.
    I think for your use, adding an external GPS antenna to Harry's probably gives you most of what you're looking to do for way under $300. You'll be able to export the data set from Harrys, combined with Race Render, or just use Harry's on your phone to do the data overlay.
  1. GPS camera with accelerometer and OBD2 input/overlay?
    By Henway in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-17-2018, 03:28 PM
  2. FS: AIM Smartycam Accelerometer/Data Overlay/GPS camera
    By Maynor in forum Race Cars & Track Parts
    Last Post: 10-16-2011, 10:48 AM
  3. FS: BNIB Contour1080p GPS Camera w/ Roll Bar Mount
    By TrickTizzle in forum Car Audio & Electronics
    Last Post: 06-18-2011, 02:57 PM
  4. Laguna Seca with Contour GPS camera
    By IVAD32 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 01-04-2011, 02:32 PM
  5. New Contour GPS Camera
    By MRichmond in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-18-2010, 11:33 AM
