Results 1 to 5 of 5
Thread: 328IS M52 to S52 ECU question
    Mar 2006
    Santa Rosa, Ca
    97 328is, 97 M3/4/5
    Hey guys,
    I am a long time member dont usally post. but love the resources this forums has. Anyways I'm getting mixed answers on this so here it goes. I have removed my M52 from my 328is 5 speed. Put in an s52. The tune I was running on the M52 was 4 M3 cams, M50 Manifold, turner shark injector. Is running this software on the M3 motor going to hurt it? Will I notice any performance gains switching the tune to M3 software from turner motorsports. Thanks guys
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    As the S52 uses the same MAF, same injectors, and in you case same cams, it will probably run quite okay.
    Though, the 400cc difference (2.8 versus 3.2) will warrant a new tune.. You'll see gains if you switch to an S52 tune, which takes into account the M50 manifold.
    1997 E36 BMW 323i
    (European) 275k km (171k miles), with following small mods:
    Long Island, NY
    1995 M3 - 2007 X5
    I would suggest retuning for the s52. I'm sure it runs just fine with the m52 tune but you're leaving some performance on the table and you should notice some gains after the switch. I swapped an s52 in place of my s50 and it ran great but it was just that little bit better when I bought a TRM chip that was specifically made for the s52 swap and the complementing mods that were already installed.
    Apr 2015
    Tennessee
    1998 BMW 328i
    Have you started it yet? Youll probably need to do some minor retuning anyways to get the EWS aligned for the new motor before it will even run. When I did my S52 swap I got a tuned DME from hakentt on the forums. Its much better than the Conforti Shark ripoff software.
    Mar 2006
    Santa Rosa, Ca
    97 328is, 97 M3/4/5
    Hello,
    Yes I started the motor drove it around the block no issues. No CEL
    Quote Originally Posted by XnWarden View Post
  1. E36 FS: e36 328i m52 AA tuned ECU for s52 cams, m50 manifold, intake, exhaust
    By busterhax in forum Engines, Performance Parts & Software
    Last Post: 02-18-2014, 10:22 PM
  2. Replies: 33
    Last Post: 05-29-2007, 04:14 PM
  3. Question: Do the m52 and s52 share the same headers?
    By djpromo328is in forum 1991 - 1999 (E36)
    Last Post: 03-06-2007, 07:46 PM
  4. DME Swap: m52 to s52. Questions...
    By jershelb in forum 1991 - 1999 (E36)
    Last Post: 09-16-2005, 10:34 PM
  5. Question: M52 to S52 swap??
    By PALELLA in forum 1992 - 1999 M3 (E36)
    Last Post: 06-29-2005, 05:47 PM
