RM European Auto Parts
Results 1 to 3 of 3
Thread: 1988 M3 Turns Over, But Want Start: Distributor or Fuel Pump?
    Dallas, TX
    88 M3,94 840Ci, 06 M6
    1988 M3 Turns Over, But Want Start: Distributor or Fuel Pump? What the best way to test?
    It's the Machine in Me!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    There are a whole lot of things besides the fuel pump and the distributor that can prevent your car from starting. But okay:
    To test the ignition system, you pull one spark plug wire, put a spark plug in it, ground the threads of the spark plug, and turn the key to start position. If the plug sparks, the ignition system is not likely your issue.
    To test the fuel delivery, you remove the fuel feed hose from the fuel rail, "T" in a fuel pressure gauge and reconnect the hose, then turn the key to start position and see whether the gauge reads 3 bar (about 44 psi).
    Chris Powell
    BMWCCA 274412
    NW suburban Chicago
    hiss by my window
    '88 M3? Won't start?
    The car is probably ready for the scrap heap. Being the generous sort of guy I am I could be persuaded to take it off your hands.
    Seriously, check for spark and fuel as already advised and let us know what you find.
  1. 1988 M3 Turns Over, But Want Start: Distributor or Fuel Pump?
    By 840ways in forum 1987 - 1991 M3 (E30)
    Last Post: 07-16-2018, 02:52 PM
  2. Replies: 4
    Last Post: 09-05-2009, 08:05 PM
  3. Questions on car not starting and my fuel pump.
    By cyb0rg in forum 1991 - 1999 (E36)
    Last Post: 12-18-2006, 04:17 PM
  4. 95' M3 turns over but randomly starts.
    By matsmouts in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-22-2006, 12:11 PM
  5. 96 E36 Start Up Problem -- Fuel Pump = Wierd
    By mini///m3 in forum 1991 - 1999 (E36)
    Last Post: 09-13-2004, 06:05 PM
