Results 1 to 4 of 4
Thread: E30/E46 rear half axles?
    Jul 2018
    Atlanta
    1992 e30 318i vert
    Will E46 rear half axles fir an E30? I know that the E46's are different sizes but I have a couple (same side/size) E46 half axles laying around and my E30 project needs both replaced. I'm hoping I can just pop in the ones I have. Thanks
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    try them, but I bet not
    No e30s again.
    Jul 2018
    Atlanta
    1992 e30 318i vert
    UPDATE - The outer joint/spindles are different. But the good news is that the inner bearing assembly is the same!! So I plan on using the E46 inner bearing on the E30 shaft.
    Also, on mine, the E46 shaft is hollow and the E30 is solid. I think these are original but am not 100%.
    I am trying to find out how to service the outer joint and if those bearing are the same between the two as well.
    Dec 2005
    No e30s, again :(
    man, that's badass. its always good to know other parts that swap in and out
    No e30s again.
  1. Help! Rt. Rear half Axle Replacement
    By redidrum in forum 1996 - 2003 (E39)
    Last Post: 03-11-2012, 12:14 PM
  2. Swapping rear half axles from an automatic to a manual
    By badeaslava in forum 1991 - 1999 (E36)
    Last Post: 02-01-2011, 01:21 AM
  3. E30 WTB E30 325 rear axles w/abs
    By JDwyer2821 in forum E30 Parts Classifieds
    Last Post: 04-24-2010, 08:31 PM
  4. Replacing rear half axle?
    By Dzem in forum 1996 - 2003 (E39)
    Last Post: 05-19-2009, 08:07 AM
  5. WTB: E30 Rear Half Shafts (axles)
    By VigilanteMotors in forum BMW Parts Wanted
    Last Post: 04-27-2005, 07:26 PM
