Results 1 to 9 of 9
Thread: 2000 e39 528i...abs coding problem....
    Jul 2018
    indiann wells, california
    2000 528i...e39
    never had any problems scanning the car at all....
    abs unit went to programma in florida for repair and upon return and installation will not
    allow scanner to connect...many attempts with different scanners. will not connect...
    any thoughts.?
    May 2013
    Chicago, Illinois
    2000 BMW 528iA
    Did they send you back the same unit or a different one? If not the one that came with the car I believe it needs to be coded to the car by the dealer.
    2000 528i sport
    EMP Stewart water pump
    Dice iPod adapter
    Alpine amplifiers
    MB Quart speakers
    MTX BGE12 subwoofer
    AudioControl EQL equalizer
    Jul 2018
    2000 528i...e39
    thanks for the reply...they sent back the same unit...i will seek out a dealer for the proper coding...any dealer..?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    mmmmm.... yeah. dealers barely know dick about programming and coding most of the time. if its the same unit then it should require zero coding. of course its possible they swapped a new board into your module case under the covers but if the place doesn't suck they should have been able to clone your car coding over to it. and as long as its the proper E39 module the only coding differences are super minor for drivetrain, there's no special VIN coding or anything that needs to be done and honestly I think the ABS module is mostly plug and play across E39' (well as long as its the right PN aka older ASC vs DSC etc. etc.)
    regardless of ALL that, there's no reason that the unit shouldn't be recognizable if you could connect to it before. nothing magic about programming/coding makes it 'visible or not visible'. it could be totally wrong coding but still should appear to a coding device/software.
    there's a lotta crappy fly by night module rebuilders (honestly I think a lotta them probably just swap junkyard guts into your case...), is this place credible? BBA-Reman is where you should have gone, but, water under the bridge.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Plus 1 on BBA-Remain
    they provided a great service, constant information, easy repair process, bench tested, and shipped my original part back FedEx. Three days turn around including shipping!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    This ^^^
    I swapped my ABS module with a rebuilt one my BMW parts guy sold me for $80 (it was rebuilt by module masters). When you swap in a new / working ABS module, you're dashboard "BRAKE" and "ABS" lights should immediately go away, but you will be left with the traction control light glowing orange until it is coded to the car. This is a 'safety' feature BMW implemented to make it so you can't swap in a 3 or 7 series module causing the traction control program to act up incorrectly.
    @OP
    1. How does your dash look before and after the module swap/repair?
    2. When you say you don't see it when you scan the car - What are you scanning with? An INPA cable? BMW Scanner 1.4.0? Etc?
    3. I'm sure you've already done this, but if not; have you tried re-seating the ABS module 84 pin connector and making sure the contacts are clean and everything is making good electrical contact?
    I'm just trying to determine if you have a badly repaired module or a wiring issue etc. If you still have the ABS 'trifecta' then I would say you likely got a bad repair as a working module regardless of coded / uncoded will ONLY make the traction ASC / DSC light turn on in your cluster.
    Also, when you're scanning your car with whatever program, does it see the car's other modules? Is the ABS module the only one missing when you scan it?
    But, as GG has already stated; if it is the same module you sent off, then it should not require any coding. Make sure it is the older ASC module if your car has the ASC button instead of DSC. BUT - Even if it is the incorrect one the ABS should still work again leaving only the traction light lit up in the cluster and the ABS and BRAKE lights should go out.
    Jul 2018
    2000 528i...e39
    thank you....EVERYONE WHO RESPONDED....HOW DO I CONTACT BBA REMAN..?
    Mar 2010
    Quote Originally Posted by robert...s View Post
    Post more in all caps. That should do it.
    Definitely don’t google BBA Reman. I’m sure that’d be a waste of time.
    2003 M3CicM6 TiAg
    Former:
    Jun 2017
    Chicago
    Please tell me these links aren't banned lmao.
    @OP Try this: http://lmgtfy.com/?q=BBA+Reman
    Also OP I would recommend proving the info to people that have posted questions for you.
    2003 530i M Sport [Black Sapphire Metallic & Sand Interior]
    IMG_1075 by Alex Wilson Photography, on Flickr
  1. 2000 E39 528i...Oil leaks, vacuum leaks, codes..ohh my!
    By justinsane187 in forum 1996 - 2003 (E39)
    Last Post: 07-10-2012, 08:46 AM
  2. E39 2000 e39 528i complete parts car
    By racerlogic in forum Drivetrain & Transmission Parts
    Last Post: 06-10-2010, 03:40 PM
  3. E39 OEM chrome grill 2000 e39 528i
    By jabdelja in forum Exterior Lighting & Body Parts
    Last Post: 10-08-2008, 09:12 PM
  4. Odd ABS Behavior (2000 E39 528i)
    By srhorn in forum 1996 - 2003 (E39)
    Last Post: 06-09-2008, 08:24 PM
  5. 2000 E39 528i Defect code definitions
    By martin23 in forum 1996 - 2003 (E39)
    Last Post: 08-12-2003, 12:12 PM
