Results 1 to 6 of 6
Thread: supposedly new top and motor need help to raise and lower
    Jun 2018
    Indianapolis
    2005 Z4
    Well after sifting through 8 pages of posts I can say with a 100% certainty that my exact problem has not been previously discussed. I purchased my car from a used car place. The guy told me that they had not only replaced the top but also the hydrolic pump. He said despite that and carefully checking the hydrolic fluid that the top still needs a hand opening and closing. He is apparently stronger than I am. When pressing the down button, the windows go down, it unlocks, the motor whirs, but, it doesn't move, if you hold the button and manually push it back to about the level of the roll bars then it falls the rest of the way, a few seconds later locks and the light goes out and windows roll back up as they should. Raising the top is more difficult. The first time you try the motor whirs, it unlocks and sluggishly starts to raise, it gets just past the rollbars and gives out and won't kick in again without shutting off and restarting the car. At this point it raises more fluidly and without help will almost close but won't lock without shutting down and restarting the car.
    As you can imagine this partial automatic top buisiness is getting rather old. Has anyone expierienced this with a new pump, or was the dealer feeding me a load of horse kacka?
    Apr 2017
    MD
    2003 Z4 2.5i
    Remember, your pump is only half of the system. It drives hydraulic cylinders at the hinges. They don't seem to fail as frequently, but it is a system of parts -- all of which need to work.
    Personally, I threw my pump away and move the top by hand. There is very little resistance with the hydraulic system open, and the electric latches still work. This solution isn't for everybody, but I'm content.
    Jun 2018
    Indianapolis
    2005 Z4
    I think I read somewhere that for the cylinders to be replaced you have to replace the whole magnisium frame. Is this true? If so it sounds like a costly repair but I would really like to have a working top and I can afford to get it fixed.
    Jun 2012
    New Jersey
    2008 Z4
    I would be willing to bet they didnt replace the hydraulic motor as those exact symptoms are what I was experiencing a few months before my motor stopped working completely.
    I replaced motor and then worked fine.
    Feb 2013
    FL
    2007 BMW Z4 E85 3.0 SI
    Quote Originally Posted by MichaelNix View Post
    If the dealer is honest the pump and hydraulic system may have not been primed and bled adequately. If the problem still exists please refer to my other post and reprime the pump as described. Post#9 in this thread:
    https://www.bimmerforums.com/forum/s...0#post30112150
    Sep 2018
    Woodland, CA
    2005 BMW Z4 3.0i
    Hey MichaelNix did you see this post?
    https://www.bimmerforums.com/forum/showthread.php?2378547-Z4-Roof-issue&p=30111750#post30111750
    The emergency release may not be fully closed creating a problem with hydraulic pressure. May be worth a try. (See post #9 from tekoo on above post)
  1. new window motor....need help!!
    By zpru127 in forum 1996 - 2003 (E39)
    Last Post: 02-24-2011, 09:32 PM
  2. new set of rims : need help
    By donchichi in forum 1983 - 1991 (E30)
    Last Post: 09-28-2003, 12:11 AM
  3. Put new HeadGasket now leaking?Need Help!!!
    By LUIS in forum 1992 - 1999 M3 (E36)
    Last Post: 08-04-2003, 03:09 PM
  4. new owner!! now i need help
    By Canatro in forum 1983 - 1991 (E30)
    Last Post: 07-16-2002, 01:08 AM
