Results 1 to 8 of 8
Thread: How do I 'hot-wire' my sunroof?
    Jul 2012
    South Yarmouth MA
    11/87 735i & 735il P/C
    None of my windows go down, I have no AC, and my fan is stuck on high but sounds like it's about to die, so I take the fuse out.
    I stripped the hex drive on the sunroof motor. I swapped in the one from my parts car and JB-welded an allen-key socket into place. Last night it randomly started pouring rain and I stripped the second one in a rush to get it closed.
    I wear dress clothes to work and I'm going to be in for a nasty week if I can't figure out a way to hot-wire the sunroof.
    Has anyone attempted this?
    1983 4-spd Mercedes 240d w/403k - Sold!
    11/87 E32 735iA w/45k - Daily Driver (finally!)
    04/88 E32 735iL - Parts Car
    Sep 2015
    Napoleon, Ohio
    94 740iL,91 850i,88 M6
    So is your sunroof switch not working then? I'm assuming you are probably using the Allen key because you can't get the motor to turn on.
    Sent from my SM-G955U1 using Tapatalk
    Jul 2012
    South Yarmouth MA
    The sunroof switch gets power (lights up with headlights), but it doesn't communicate with the control module under the rear seat. I've tried swapping switches, but no luck.
    I basically need a diagram of hot/ground going into the sunroof motor
    Jul 2015
    Montreal, QC, Canada
    09/87 E32 750iL
    Wiring diagrams are here.
    Jul 2012
    South Yarmouth MA
    Quote Originally Posted by kce1900 View Post
    I appreciate the link, but honestly I can't make any sense of the diagrams without pictures. I am praying somebody might be able to tell me what wires to cross, and where they're located from their own experience. I know that's a big ask though.
    Brantford ON Canada
    735iL - 1989
    Quote Originally Posted by CamE32 View Post
    I would try this first:
    Owner's Handbook: Insert key [in the driver's door lock from outside the car] and hold it in the central locking or unlock inhibit position. This will allow the windows (right side first, then left) and/or the sunroof to close in succession. Releasing the key will automatically interrupt this function.
    Jul 2012
    South Yarmouth MA
    Quote Originally Posted by E32FAN View Post
    No luck
    For some reason I cannot turn my key all the way to the unlocked position, and when I lock it and hold it all the way horizontally, nothing happens. Neither of the door locks work with the key or interior button
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Then I would check for broken wires in driver door. Point to start is between A-pillar and door. There is a good DIY with pics on the German 7-forum, 1.05 MB to download http://www.7-forum.com/forum/showthr...t=118598&page=
    Hope you can download the pdf without registering there first
    rear door http://bmwe32.pagaduan.org/Kabelbruc...nks_hinten.htm
  1. Can I "hot wire" my bmw???
    By BMWFAN in forum 1991 - 1999 (E36)
    Last Post: 01-03-2021, 09:09 PM
  2. Angel Eye hot wire?
    By fastfly in forum 1991 - 1999 (E36)
    Last Post: 02-19-2005, 07:04 PM
  3. just hardwired my V1 to wires to sunroof
    By shark328 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-16-2003, 12:11 PM
  4. Hot wire in sunroof pannel??
    By Bham BMW M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 07-03-2003, 02:53 PM
  5. Which is "ignition" wire on sunroof switch?
    By achilles99 in forum 1991 - 1999 (E36)
    Last Post: 05-07-2003, 11:13 AM
