Mint condition ENKEI NT03+M rims square 18x10 used only once!!!! Mounted on race slicks 275 square continentals! Stored in bags with covers must go !!! Bored out for e39's can also fit other models with rings ! Rims are light and can be used with nitro !! THOSE WHO ARE NOT READING THE LISTING PROPERLY PLEASE NOTE THESE WERE ON A BMW E39 !! THEY WILL WORK ON E36/E46/E90's AND YES BOLT PATTERN IS 5X120 ET25 I CANT MAKE IT ANY MORE SIMPLER !!!! Good luck and thank you PRICED TO GO ASAP
$1250
2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4”cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50”
