This listing is for my turbo kit but these other parts are available also would like to sell whole car as whole or the large items first before I decide to part out as far as turbo kit and built motor supertech dual valve springs vac cams cut ring head gasket je pistons with eagle rods all new bearing and gaskets built motor in September .car is a 1995 m3 coupe white .it has one piece dss shop drive shaft 750 big diff along with revshaft rear subframe bushings akg short shifter bilstein struts with ibach springs and sway bars for got what mm they are but I bought every thing brand new.has twin disc competition clutch bought from maximum psi e85 fuel lines which are -6an for return and -8an for feed with aeromotive fuel pressure regulater and rally road racing fuel rail, also bought rally road racing metal tranny bracket or brace but never installed in car,also has sparco front seats that slide and recline aem oil pressure guage r888 toyo drag radials and a set of k1 racing light weight wheels.all car needed is dss arear axles to be a complete nice set up.
But as far as the turbo kit,its a complete turbo kit still and is from my personal car it made 700whp and 700wtq at 21 psi tuned by rk tunes it is turn key its still in car and all are welcome to come get a test drive and inspect many other parts available complete turbo kit include 6466 dual bb precision turbo gen 2 custom top mount turbo manifold 3 inch down pipe to stock m3 drum with qtp electronic cut out which is very nice all gauges needed which are tru boost boost controller and aem air fuel guage car ran on e85 115lb injectors and wallboro e85 intank fuel pump threadstone intercooler 3 inch intercooler on cold side and 2.5 on hot side tial blow off valve and waste gate many other parts included or can be included if interested please call or text me at 347 546 4555 thanks
I started a you tube channel but didn't continue but you can see some of the build and parts, the youtube channel is e36craze or check out my instagram @e36_craze
