Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: FS Ignition wires for M70 and M73 engine
  1. #26
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    here a pic with numbered temperature sensors in the back of the M70 engine, easier to understand
    Attachment 704136
    Nr.... Sensor type.......................................connect s to
    1 intake air sensor bank 1......................DME1
    2 intake air sensor bank 2......................DME2
    3 double temperature sensor coolant.......each one sensor for each DME
    4 temperature coolant............................EML
    5 temperature coolant............................temperature gage in instrument cluster
    in front of the engine we have these
    Attachment 704137
    Nr................Sensor type.........................................goes to
    1......crankshaft position sensor CPS bank 1...............DME1
    2......crankshaft position sensor CPS bank 2...............DME2
    3...cylinder identification sensor CID / donut bank 2....DME2
    4...cylinder identification sensor CID / donut bank 1....DME1
    Bosch 2500Ohm Sensors, NTC 2500Ohm at 20°C
    Temperatur [°C] ......R [Ohm]
    -40........................45.313
    -30........................26.113
    -20........................15.462
    -10.........................9.397
    0............................5.896
    10..........................3.792
    20..........................2.500
    30..........................1.707
    40..........................1.175
    50...........................834
    60...........................596
    70...........................436
    80...........................323
    90...........................243
    100.........................187
    110.........................144
    120.........................113
    130..........................89
    Bosch 5kOhm Sensor, NTC 5kOhm at 25°C +/-2%
    Temperature [°C]......R [Ohm]
    -30..........................88.700
    -25..........................65.300
    -20..........................48.500
    -15..........................36.400
    -10...........................27.600
    -5.............................21.100
    0...............................16.300
    5...............................12,700
    10...............................9.300
    15...............................7.800
    20...............................6.200
    25...............................5.000
    30...............................4.000
    35...............................3.200
    40...............................2.600
    45...............................2100
    50...............................1.800
  2. #27
    Jan 2005
    Japan
    @Ericks2002, 1 set M70 ignition wires shipped to Houston, Texas
  3. #28
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    Hi Shogun - looking for a set of leads for my M73, if they are still available please? UK address, thanks
  4. #29
    Aug 2019
    '95 540/6, '01 750iL
    Also interested for an M73 application @shogun!
    TIA!
    -Jon
  1. FS Ignition wires for M70 and M73 engine
    By shogun in forum Parts for Sale
    Last Post: 01-20-2023, 10:46 PM
  2. Ignition wires for M70 and M73 engine
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 04-02-2021, 08:02 PM
  3. How can I tell the difference between M70 and M73 engines
    By djinnaroth in forum 8 Series (E31)
    Last Post: 04-21-2012, 08:30 PM
  4. INFO-> E31 M60/M62/M70/S70/M73 Engine Specs and Differences
    By ProStreetDriver in forum E31 Common Problems and DIY Fixes
    Last Post: 04-19-2010, 11:52 AM
  5. FS: E30 M3 (S14) Magnecor Ignition Wire Set
    By M-Technique in forum BMW Parts For Sale
    Last Post: 11-29-2004, 04:57 PM
