So I just recently traded my 328is for an '84 325e that I thought was a pretty solid little car. That is until I decided to investigate what I thought was a small rust hole. Turns out, both the driverside and passenger side floor boards are damn near completely rotted out. It seems to have typical rust now that I am familiarizing myself with the problem areas on the E30, but the exterior of the car shows no signs of rust whatsoever.
I have gotten quotes on rust free used panels from bmrparts already, but they're a bit steep for me right now. I found a website called wallothnesch.com that sells a lot of structural E30 parts but unfortunately not floor pans. They do, however, sell floor pans for the E21. I was curious if anyone was familiar enough with both cars to know if there is any interchangeability between the floor pans at all. Otherwise my last option is to have a local sheet metal company make floor pans for the car, although I am unsure how I feel about installing non-oem like floor pans because I think it will mess up the pedal mounting, as well as the seat mounting. If I have to do custom floor pans I suppose it's just going to become a race car.
I was hoping someone could shed some light on this subject for me and maybe if there are any more options. I manage a body shop so most everything is not really an issue to have done to my car.
The e21 is a fair amount smaller than an e21 so i dont think it will work
No e30s again.
You could always fab up you own. My driver's floor pan was gone. I used a PC side cover and hammered it into correct shape. Welded in place and cleaned up the welds and it looks good enough.
1991 318is
2001 740i
Nice work
Sent from my SLA-L22 using Tapatalk
Sadly for the E30 you're going to be doing custom fab work to repair floor pans like bymep did.
bymep - very nice/clean fix!
-James
