Results 1 to 5 of 5
Thread: Windshield gaskets and trim
    Aug 2011
    Metairie, LA, USA
    1985 BMW 745i, & 635CSI
    In preparation for paint I’m searching up all the rubber I need and been ok in finding most. I can get a front windshield gasket for about 250. Rear is nla. A few years ago I was looking into this with my other car and the glass guy mentioned he could make up a gasket. I didn’t pursue it because they were easy to get at the Time and were about 100 bucks. Not any more.
    Any body have experience with getting the glass company or somebody else to make up a gasket? Can’t seem to find good info on it.
    Sent from my iPad using Tapatalk Pro
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    That seems unlikely since, if memory serves, the profile of the rubber is not the same all the way around.
    --Jay3->Sic gorgiamus allos subjectatos nunc
    84 €735i manual, 88 528e/i
    Motronic 1 and 1.3 wiring
    Transmission & Diff gearing sheet
    May 2013
    Killingworth, CT
    '84 733i, 01 X5 00 750iL
    Universal windshield extruded molding rubber stock is used for cosmetic molding, not for a gasket set windshield like these cars. The glass guy most likely was not familiar w/ the car and saw the rubber molding and assumed it was cosmetic, and that the windshield was urethane set, which it's not. If you look up aftermarket glass molding supply companies like GGG you can see what sort of universal extruded rubber is available to glass pros. I have done some windshield work and do not ever recall seeing extruded rubber to make a windshield gasket like you'd need.
    https://www.gggcorp.com/Universal_Mouldings.html
    Steve H.
    Aug 2011
    Metairie, LA, USA
    Quote Originally Posted by BONDOSPECIAL View Post
    Ok that makes sense. Now what to do when one is NLA?
    May 2013
    Killingworth, CT
    Good used is probably your only option. If yours is torn up, try to find a better used one. The rubber these were made out of holds up well.
    Steve H.
  1. Windshield gasket replacement procedure?
    By Battledad in forum 1995 - 2001 (E38)
    Last Post: 07-26-2013, 12:28 AM
  2. E36 top windshield gasket
    By SneezyMcFartLeg in forum Exterior Lighting & Body Parts
    Last Post: 08-05-2009, 03:07 PM
  3. Lower windshield gasket coming apart
    By giantrobot9000 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-14-2007, 01:11 PM
  4. FS: Brand New Windshield Gasket & Trim Strip Set...
    By Ben Carufel in forum 1983 - 1991 (E30)
    Last Post: 04-12-2007, 11:03 AM
  5. e36 coupe Windshield gasket/moulding
    By Asheville325is in forum BMW Parts Wanted
    Last Post: 04-18-2006, 02:19 PM
