Will Both trailing arms work with a z3 2.8 coupe?
― George Orwell
The trailing arms should work with a Z3 2.8 Couped as the body and mounting points for the subframe and diff are identical. However I think you may need to also use the subframe from an "M" to make them work (which I'm also selling) as the geometries may be different. But I'm not positive. I'm also not sure if the length of the output shafts from a Z3 M and none M are the same so you'd need to check on this and also to make sure the diameter of the splines going into the wheel bearings is the same. I'd bet someone on the forum here could answer these questions You could check with Randy Forbes he might know for sure about all.
Thanks will do
― George Orwell
Looking for M axles if you have any
PRICE CUT on ALL FABRICS
Messaged
Hrmmmi
― George Orwell
