Results 1 to 6 of 6
Thread: Odometer gears
    Jan 2012
    Vancouver, BC Canada
    1985 Mercedes 300SD
    Odometer gears
    So I finally managed to take my e23 project out for its first time on the road in at least 4+ years, it was great. However of the many things that don't work on it, the odometer\trip is one of them. I'm assuming bad gears. Odometer gears however requires you to know how many teeth are on them. I'm being lazy here, but am wondering, do all e23's really have a different number of teeth?? Or are they just covering themselves and there is one that I can just order and be assured it will fit.
    Jan 2012
    1985 Mercedes 300SD
    Anyone?
    Quadratechtown, PA
    5, 7, 4x4
    Call and talk to em. They probably know what you need if you know about the speedo/cluster in your car.
    Jan 2016
    Ca
    2001 525it
    Let see the company who makes the gears requires you to know how many teeth because they must have made different types for that year well just take it apart and count the teeth, your going to have to take it apart anyway. How hard is that.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Probably has to do with the 140 and 160mph speedos, it does not take long to pop the thing apart.
    FWIW, you may as well find an updated SI board while in there...
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Dec 2005
    Omaha NE
    84' 533i Turbo
    Go to odometergears.com you'll find what you need there.
  1. 12-tooth odometer gear
    By eibowow in forum 1983 - 1991 (E30)
    Last Post: 08-22-2006, 03:22 PM
  2. Odometer gear replacement
    By Shaladdle in forum 1983 - 1991 (E30)
    Last Post: 05-06-2006, 02:40 PM
  3. Replies: 8
    Last Post: 02-09-2005, 02:01 PM
  4. Replies: 0
    Last Post: 02-07-2005, 03:40 PM
  5. WTB: e30 odometer gears
    By havand in forum BMW Parts Wanted
    Last Post: 09-07-2004, 12:55 AM
