Results 1 to 6 of 6
Thread: Opinion on my transmission dilemma?
    Feb 2012
    Southern Ontario
    93 850Ci, 2012 X5 35d
    All prices are in Canadian dollars...
    I developed a severe leak from the pump seal on my 4HP24 transmission in my 850. Estimates from dealers and local shops were from $2000-$3200 to rebuild the pump and repair. I found a reputable shop, highly recommended, they did it for $1600 with a one day turn around. the shop is 3 hours from me, as I live in a remote area. I had the car taken there by CAA, when I picked up the car, it had now developed the dreaded hard shifting (it didn't do that before), and shifting all over the place. They recommended I find another valve body, they would rebuild it, then bring the car back for a changeout. I found a valve body for $275 and sent it over to them. They after I sent it out, the next morning I was accellerating and after one big bang, I coasted to the side of the road, The car wouldn't rev past 1500 RPM in any gear or park, It would not move in any gear. I had the car CAA towed to the transmission shop. I haven't seen it, but the tech says he's never seen anything like it, and told me to look for another transmission. I found a used 4 HP 24 for $900, and am driving the 3 hours there and back to take it there. They will rebuild it, and install at no charge.
    My question is...shouldn't they be on the hook for it blowing up? should I ask to meet me halfway? It never ran correctly after they worked on it, and told me I was ok to drive until the valve body was changed out...Am I way out of line here?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Just a guess, maybe they did not install the torque converter correct and that destroyed the input shaft https://www.europeantransmissions.co...rter_insta.htm
    https://www.jegs.com/InstallationIns.../555-60401.pdf
    Feb 2012
    Southern Ontario
    Quote Originally Posted by shogun View Post
    what got me was the last line of your link...it did have a whine to it before the big bang...
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    www.eurotransspecialists.com are the only guys in the USA that still remanufactured the 4HP24 that I know of... and they are better than new. All in, you'd have spent less getting a unit from them. I put one in the TT 750 and it is sweet...
    Jan 2005
    Japan
    whine often comes also from too low ATF level or not proper fitting O-rings on top of the trans filter, then besides ATF the pump also sucks air = causing whining sound.
    Here some samples of bad fitting O-rings we found when making trans service on 4HP24 http://e32b12.blogspot.com/2012/10/t...er-o-ring.html
    Feb 2012
    Southern Ontario
    Quote Originally Posted by cartoonz View Post
    In hindsight yes, it probably would have been cheaper, but it went in for a leaking pumpseal...would you buy a new transmission if you had a leaking seal? It went from there...
    I'm picking up and dropping of the used 4 HP24 today, I'll be able to look at the damage in my original this afternoon when I drop it off...that should tell the tale...
  1. Transmission dilemma (long post, sorry)
    By jicaino in forum 1996 - 2003 (E39)
    Last Post: 02-17-2014, 05:08 PM
  2. Opinions: Unlock Valve Transmission
    By THEREDTUXEDO in forum 1999 - 2006 (E46)
    Last Post: 06-25-2012, 10:18 PM
  3. 325i transmission dilemma
    By strikezone17 in forum 1991 - 1999 (E36)
    Last Post: 09-26-2008, 12:04 PM
  4. ok my dilemma, E36 M3 vs. E46 330ci... opinions needed
    By M Technic in forum 1992 - 1999 M3 (E36)
    Last Post: 09-30-2002, 08:14 AM
  5. Anyone installed a 6-speed transmission? Opinions ?
    By 99M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-13-2001, 01:21 PM
