Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 59
Thread: I bought another car...
  1. #26
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    ^ I did earlier today and its still doing it. No dice
  2. #27
    Jan 2014
    San Antonio
    98 328is
    Quote Originally Posted by Piner View Post
    I honestly don't remember the part number, I'll have to go look at them. Its been more than 4 years since I bought them but I think they cost me $300 for the pair loaded with pads. Now wilwood makes a handbrake specific pad for them but im just using their street pad on it. I also think i want to move down in master cyl size. I have a 3/4 on there right now but its low travel/ high effort to lock the rear up. I feel like the 5/8 would be too easy to pull with more travel than I want. Looking on Wilwoods site they do sell that same style master in a 0.7 inch piston. Just a tad smaller than the 3/4 that I have which should be a perfect middle ground. I am going to play around and see how this event goes and then maybe I'll swap out for a .7 master as its only about $66.
    just a heads up, there is a 15% ebay coupon today only. i just picked up the .7 master for $49 shipped. That particular vendor only had 2 available. the rest should be about $53 shipped
  3. #28
    Aug 2008
    Lakeland Florida
    Good looking out man,
    I think I am going to use the 3/4" master for the time being atleast until I put some power in this thing and start running more rear grip. I didn't have a problem locking the rears up at the last event I drove.
    I got my tuned ECU in the mail and loe and behold it works great. Pulls clean to 7k and is running better than ever (Means it'll blow up soon).
    I got tires mounted up and I am ready to drive at Sebring tomorrow. There is a little competition for solo class and since I don't have a cage in this thing yet I am going to see how I do in that. Will be the first time on track with this thing running right. Also pretty excited to drive at Sebring, motorsport royalty as far as tracks go.
  4. #29
    Jan 2014
    San Antonio
    98 328is
    who did you go with for te ECU tune? blew the HG is my 328 a few months ago, finally getting around to fixing it, and i somehow ended up with some M3 cams and catless exhaust with ebay headers. So i may looking for a tune soon.
  5. #30
    Aug 2008
    Lakeland Florida
    It was one of those ebay listings for a tuned ecu from moldova. This listing here https://www.ebay.com/itm/BMW-Chip-Tu...72.m2749.l2649
    Shipping was a bit slow but to be expected since it came from europe. It was a good deal since I didn't have to send my dme as a core and it did exactly what I needed it to do.
    So its the day after Sebring. I had a good time, as to be expected its was hot as hell since well florida, I drank a gallon of water over the day. I started off the event a bit unprepared since there were only 11 drivers that showed up for the solo class and since we had our own layout that was seperate from the tandem guys that equaled out to a lot of track time. I only had 4 new tires to drift on plus a set of used tire to drive home on. I spent most of the day trying to conserve my tires so I'd have something to drive the competition on. Drove way more practice runs that I had expected to do because I kept holding out hope for nailing a run with the 3rd gear upshift in the middle of the course that I later realized with my higher rev limit wasn't necessary. Once I realized I could stay in 2nd for the whole course that really changed the way I drove and started nailing the course.
    I went into the comp thinking I wasn't going to do very well and it turned out after a few one more times including an OMT for first place (With the guy I was sure was going to win after watching for a good portion of the day) I took myself out by driving off line on the very last run and ended up in second place. 100% my mistake, the car was doing what I wanted all day I am still feeling out this things potential.
    Pretty satisfying to take the lowest powered car in the field (Next lowest was about 200hp, the winning car is 389whp) and get 2nd place in my second event in the car. I can't wait to get this thing dialed in and start driving more
  6. #31
    Aug 2008
    Lakeland Florida
    The last run in the video is my second to last run, I forgot to hit record on my final run when I fucked up and took myself out.
  7. #32
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    Sebring would be so much fun to drive. I have heard that the surface is INCREDIBLY hard on tires.
  8. #33
    Aug 2008
    Lakeland Florida
    Well went and did another Sebring event,
    Changes on the car include:
    Swapped out the Getrag 420G for a ZF320, The 3rd gear syncro issue was annoying the hell out of me and keeping me from driving the car as hard as I wanted to.
    Swapped in my 3.15 3 clutch LSD, So much nicer to drive than the welded.
    M50 intake mani
    Redrilled the strut tops for more caster
    here's video of my fastest entry from the weekend. I really want more power so it doesn't take starting off at half the straight to get up to 100mph.
  9. #34
    Mar 2011
    PNW
    LS E46
    Less handbrake, more flick. Technically shouldn’t even need the handbrake at all but I admit I’m still trying to master that as well, I still need a dab of it to do what I want.
  10. #35
    Aug 2008
    Lakeland Florida
    Well this is just one run, I did many others that were more heavy on using more angle to slow down. I leaned on the handbrake more on this run since the tires I was using this run had dramatically less grip (had less grip at 25psi than the previous set at 65psi) than the others I had been on that day and didn't really trust them. Like I said this was my fastest entry of the day but didn't have much faith in the tires digging me out at more angle.
    This course with my current setup I highly doubt it would be feasible to not use any handbrake at all going that fast and honestly what would be the point other than stroking myself off?
  11. #36
    Mar 2011
    PNW
    LS E46
    Because no angle. Looks extremely underwhelming from the outside. Don’t forget, drifting is about overall excitement.
  12. #37
    Aug 2008
    Lakeland Florida
    Oh I totally forgot about that thanks for reminding me oh drift sensei. I was totally lacking in angle all day and everyone was bored to death, I now understand why.
  13. #38
    Mar 2011
    PNW
    LS E46
    You’re the guy posting vids of yourself.
  14. #39
    fairfax,va, usa
    2 E30s and a maxima
    Video gone. I wanna see!
    The problem with a subjective sport is that everyone has opinions. Over use of hand brake, under use. Low angle. No style in the car. Blah blah.
    hakuna matata
  15. #40
    Apr 2017
    NJ, USA
    '07 335I 6MT, '01 330i
    Ah, Liquidity, back at it again after his time away. It was so pleasant without him....
    Piner- How far did you drill your strut tops for more adjustment?
    Sebring looks like fun.
    Keep it simple: half gutted '01 330i, welded diff, BC coils, SLR Super kit
  16. #41
    Aug 2008
    Lakeland Florida
    ^I reversed the strut pattern since the SLR top plates combined with the e36 pattern do not allow more positive caster adjustment only less. Didn't really want to dril into my strut tops but I wanted more positive caster so I felt it was worth it.
    Also found some photos from the event of my low angle driving
    62609566_434702747349129_4664127899824029696_n.jpg62118540_589935898164957_6146713038029324288_n.jpg61927336_1293383727493804_3457364874173087744_n.jpgATA_1375-Edit.jpg
  17. #42
    Aug 2008
    Lakeland Florida
    Other point of interest, Ryan our Fabricator who builds all the control arms for SLR did I think 8 or 9 laps in the car. Reason why that is significant is he has been building our arms for 5-6 years now but has never actually drifted a car with a kit on it and got to experience his handiwork. Its a bit ironic though the kit on my car is a 2012 vintage kit well before he worked for us so he didn't build these arms, they were made by the same guy who built the roll cage in my black coupe. I'd really love to buy a brand new kit and put it on the vert but the old stuff still works so well it would really just be a cosmetic upgrade more than anything.
    Plans for the car before the next event are mainly switching to E36 non-M front knuckles. The E46 non-M knuckle's trail leaves a lot to be desired. Even with the large increase in caster from the strut tops the self steer although much better still doesn't match my black coupe. The non-M e36 knuckle has considerably more trail and should feel better.
    Then I think I'm gonna focus on making the car look good, bodywork, paint and all that. As far as power goes, I am a bit torn between just throwing all my turbo stuff on it or going for what I really want and throwing a Maserati 4.2L V8 in it.
  18. #43
    Apr 2017
    NJ, USA
    It's CRAZY you mention a maserati 4.2... I was looking at those motors recently! They can be had stupid inexpensively... and the sounds the make....
    Would you be making up a custom adapter plate to the ZF?
    As far as your drilling- it kind of looks like that's the least impact on the structural integrity as you could possibly have. Seems like it's a good method.
    Low angle driving never looked better.
  19. #44
    fairfax,va, usa
    2 E30s and a maxima
    Why not M E36 for bigger brakes? That's what I have on my E46
  20. #45
    Aug 2008
    Lakeland Florida
    Quote Originally Posted by awp235 View Post
    The Maserati engine has been on my mind the last year or so when I came across a craigslist ad for one then I started doing some research into it. Found out all the things you listed and some other cool details that make it very desirable to me. Things like the facotry drysump system on the earlier engines, the fact that despite being a DOHC engine it has weight parity with an all Aluminium LS1, full bedplate bearing cap arrangement, etc. There are a lot of really cool details on that engine and the price is super temping. I've become a little bit obsessed with the idea of doing the swap, I just have to pull the trigger on a running copart car.
    I was toying with the idea of using the torque tube/ rear transaxle setup since we have one here at the shop for mock up, turns out the output flanges are the same as E46M3 so M3 axles bolt up to it. The F1 transaxle can be easily converted to full manual by using a cable shifter and a regular hydraulic throw out. But the space constraints in the E36 means I'd have to build a custom subframe, run a fuel cell and figure out a host of other packaging problems that I don't really want to deal with. So yes I am thinking an adapter plate for the ZF makes the most sense. Starter is on the engine in its own cutout on the engine side, the factory flywheel/clutch assembly is pretty small so it shouldn't be hard to fit it's pattern inside the BMW pattern. I talked with some companies that tune the ECU's and well they seemed a little bewildered when I asked about them turning off all the can function and anti-theft stuff. Wiring seems rather simple and all the electronics are just off the shelf Bosch ME7 stuff so a standalone should run all that stuff pretty easy. The factory Headers are pretty compact and the engine makes plenty of power with them already so I'd probably try to stick with them.
    Lots of other little details I've been thinking about but if Im going to do it I need to just bite the bullet and buy a salvage car and start doing some measurements.
  21. #46
    Aug 2008
    Lakeland Florida
    Well the e36 M3 knuckles although they do have more trail than the e46 non-M, the E36 non-M has the most trail out of any of the 3 series knuckles, its what I was used to on my Black 325i and my old 328i. For larger brakes I'd just go with E46 330Ci brakes since they are very similar in size to e36m but they will fit on non-M knuckles without issue. I don't feel like I want larger brakes on the front of the car and I think I'd rather have smaller rotors with less rotational mass.
  22. #47
    fairfax,va, usa
    2 E30s and a maxima
    Why you gotta make me second guess getting M knuckles? My rears are now E46 M3 so I feel like non M E36 front brakes would be... smaller than my rears lol.
  23. #48
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    IIRC didn't chelsea run E36 non M knuckles on his 46 FD car?
  24. #49
    fairfax,va, usa
    2 E30s and a maxima
    Yea but he also likely had wilwood brakes. Oh yea IIRC the M3 knuckles have beefier wheel bearings. The non Ms wear out faster.
  25. #50
    Aug 2008
    Lakeland Florida
    Yeah we've been telling our dudes running competitively to use E36 Non-M knuckles on their E46's. We are working on a High trail steering plate for E46's to solve their low trail problem. The first batch should be available soon. My car is looking to be the test vehicle since despite having a bunch of drift cars in the shop my vert is the only one that runs lol.
  1. I bought another car....check it
    By Inv3ctiv3 in forum BMW Rides & Events
    Last Post: 08-09-2007, 11:09 PM
  2. bought another car
    By gelf74 in forum 2002
    Last Post: 03-05-2007, 04:51 PM
  3. Bought another car
    By BIMMERBOYZ in forum 1975 - 1983 (E21)
    Last Post: 07-16-2005, 04:29 PM
  4. Bought another car yesterday -- Coupe retired to weekend duty...
    By Ben Carufel in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-24-2003, 12:57 PM
