RM European Auto Parts
Results 1 to 4 of 4
Thread: E36 - Upgrading to 140amp alternator, do I need a new voltage regulator?
    Jul 2018
    St. Paul, MN
    98 & 99 M3, '06 E60M5S3
    Hey folks,
    Simple question, I tried searching the forum as well as The Google with very little luck. I'm replacing the original 80 amp alternator (with 398,000 miles on it!) and going to use a 140amp alternator due to a car audio upgrade, and simply to get ride of the annoying electrical glitches and annoyances. Do I need a voltage regulator, or do I need to do anything else besides simply pulling out the old one and putting in the new one? Will the existing wire be able to handle the higher amperage?
    Thanks a ton for your help!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    The voltage regulator is part of the alternator.
    A 1998 M3 had an 80 amp or a 140 amp alternator. The 140's part number is 12311744567. The wiring harness wouldn't have changed for the different alternators.
    Chris Powell
    BMWCCA 274412
    Jul 2018
    St. Paul, MN
    Thank you much!
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The pulley spacing is different. Usually the Bosch comes with the pulley. If it does not, you cannitvseap thebibevftom the Valeo andceill Gabe to buy the Bosch pulley. I also recall grinding a tiny bitbofvthevxase to add clearance but I had a supercharger then and maybe it was due to the bracket for that. Can’t remember — it was in 2006.
  1. New Voltage Regulator - Alternator Overcharging
    By 5Toes in forum 1988 - 1996 (E34)
    Last Post: 04-29-2018, 12:23 AM
  2. brand new voltage regulator for e36 bosch alternator
    By Arctikz in forum Engines, Performance Parts & Software
    Last Post: 02-10-2012, 01:15 PM
  3. do i need a new window regulator? or??
    By JE BMW in forum 1991 - 1999 (E36)
    Last Post: 01-26-2011, 04:04 PM
  4. Need A E34 Voltage Regulator....
    By klentz13 in forum 1988 - 1996 (E34)
    Last Post: 03-28-2009, 07:23 PM
  5. Whole new alternator or just new voltage regulator?
    By brogenville in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2006, 08:38 AM
