Results 1 to 21 of 21
Thread: Headlights dipping -
    Dec 2007
    orange, ca
    '91 e31
    Here's the problem with being around here so long and also with getting older - I've read every thread here and on the old board, so I've seen (almost) every problem posted and resolved - but I can't remember the solution!
    In the last couple of months my headlights have been getting a little wonky. When I turn on the lights, they lift to the proper position and then drop about 1/2 way. Sometimes I have to raise the hood and manually raise them into position to drive home at night. Later, when I turn them off they drop - and then raise back up about and inch or two.
    Is this a GMII thing? What else should I be looking for?
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    What at kind of shape are your headlight shocks in? If they have never been replaced I would suggest they be one of the places to start.
    Quote Originally Posted by rockytt View Post
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    Apr 2009
    Ridley Park, PA
    91 850i x2, 92 850i 6sp
    Sound like it could be a headlight relay in the fuse box problem. The rely switch gets some hairline cracks in the base connection the need to be resoldered.
    Dec 2007
    orange, ca
    '91 e31
    I changed them out about 5 years ago - so I'm hoping that's not it.
    Sound like it could be a headlight relay in the fuse box problem. The relay switch gets some hairline cracks in the base connection the need to be re-soldered.
    Well that doesn't sound fun
    So this isn't a matter of just replacing a relay, but fixing the fuse box? (fun...)
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Lkm...
    '93 850Ci - Mineralwei゚ Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinwei゚ III
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Sounds like, as has already been said, K39, it can be replaced or repaired (they are not cheap from BMW):
    https://www.meeknet.co.uk/e31/Timms_...lay_Finder.htm
    My BMW Repair YouTube Channel
    Apr 2009
    Ridley Park, PA
    Easy repair for me and I know nothing about soldering either, just bought a cheap soldering station online and had at it.
    Just take the k39 relay out, open the plastic coverand inspect the connection very closely as they are hard to spot.
    Dec 2007
    orange, ca
    '91 e31
    Thanks for all the suggestions - I guess I can take a whack at k39 - worst case, I have to bite the bullet and buy a new one -
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    With bad shocks, they still stay up fine as there is a hinge on the opposite side. I vote relay based on a historical reading of this forum.
    What "thumbs up" really means
    Dec 2012
    Palm Beach, FL
    Alpina B9 Trib, '91 850i
    Good morning. My headlights are sometimes not coming up, sometimes only 1 side, etc. Could someone point to me where I could source the K39 relay recommended above in the hopes it’s a simple swap? Dealer? Part no.?
    Thanks!
    Apr 2009
    Ridley Park, PA
    also just solder those connection up super easy no need to buy a new one.
    Dec 2012
    Palm Beach, FL
    So the only source to get a relay is in the UK which would realistically take weeks to arrive? Does anyone have a part no. for this relay in case a dealership stateside may have one available?
    Dec 2007
    orange, ca
    '91 e31
    61351392413
    There are a few on the 'bay too
    (and that was kind of big jump to "
    the only source to get a relay is in the UK which would realistically take weeks to arrive")
    Dec 2012
    Palm Beach, FL
    I surmised that was the case as it was the only reply received on where to get it. Just went on eBay and got nothing. Please pm if you have/find one and many thanks!
    Dec 2007
    orange, ca
    '91 e31
    I just entered "61351392413" in the search bar and got 3 results. (2 are from the same company, and one is from Latvia - but the one for 89.99 should work fine)
    Apr 2009
    Ridley Park, PA
    Find someone to solder yours, or you could just send me your and I’ll do it for you. Super easy fix.
    Dec 2012
    Palm Beach, FL
    Pniell316 - that is as genuinely nice an offer to help and I知 so very humbled by your generosity.
    My relay looks fine - there is nothing physically wrong with it, so I知 afraid that soldering wouldn稚 be the cure? I値l be the first to admit that I知 not mechanically inclined, although can clearly recognize something that has broken...
    I知 still dealing with the intermittent headlight buckets not coming up or down as they should. The sole replacement relay on eBay obviously comes from another used (and 25+ years old) e31. Should I just pull the trigger on that one which hopefully will last me a while or? Sorry for harping on this thread as much but it痴 become annoying when they won稚 work as intended!
    Apr 2009
    Ridley Park, PA
    Quote Originally Posted by OttoB View Post
    Pniell316 - that is as genuinely nice an offer to help and I’m so very humbled by your generosity.
    My relay looks fine - there is nothing physically wrong with it, so I’m afraid that soldering wouldn’t be the cure? I’ll be the first to admit that I’m not mechanically inclined, although can clearly recognize something that has broken...
    I’m still dealing with the intermittent headlight buckets not coming up or down as they should. The sole replacement relay on eBay obviously comes from another used (and 25+ years old) e31. Should I just pull the trigger on that one which hopefully will last me a while or? Sorry for harping on this thread as much but it’s become annoying when they won’t work as intended!
    It could still be the relay, those cracks are hairline and really hard to see sometimes. If you do end up buying a new relay, feel free to still send me the old relay and I can see if I can fix that one for you and then you’ll have a spare in case the new on goes one day.
    Dec 2012
    Palm Beach, FL
    I believe that the one(s) on eBay are also used... it should not matter then if it appears that no cracks are present if I buy it? I知 somewhat reluctant because of a possible no return policy on a used electrical item.
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    I have 5 spare 413 relays that have all been opened, inspected, resoldered and tested in my own 91 E31. Would be happy to seel you one, Contact me by PM or at: wuffer at shaw dot ca
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Oct 2017
    Nashville, TN
    1995 BMW 840Ci
    OttoB- open hood, start car, you can hold down k39 relay and reach headlight switch at same time, while applying a little pressure to the relay turn on lights. If both lights operate properly you know it’s cracks in the solder joints on the base of the relay. If they still fail you don’t know anything new...could still be solder joints but cracks that downward pressure didn’t push back together. If you can prove it’s the solder joints it may make you feel better when you try to fix or get one from Wuffer.
  1. Euro headlight dip switch
    By Ricardo Dude in forum 1983 - 1991 (E30)
    Last Post: 05-03-2015, 02:01 PM
  2. E39 528 -96, low beams or dipped headlights doesn't work!
    By Naikon in forum 1996 - 2003 (E39)
    Last Post: 04-02-2013, 01:19 PM
  3. Passenger Dip headlight keeps blowing.
    By JerCotter7 in forum 1991 - 1999 (E36)
    Last Post: 11-21-2010, 04:54 PM
  4. FS /// E36 K&N Air Filter, Airbox, Dip Stick, Injectors, Headlights, Dinan DME, etc.
    By Silex in forum Engines, Performance Parts & Software
    Last Post: 07-29-2008, 10:49 PM
  5. Change headlight dipping
    By kalexa in forum 1999 - 2006 (E46)
    Last Post: 11-07-2006, 11:07 AM
