Results 1 to 9 of 9
Thread: Parasitic Drain Test - Put car to sleep?
    Jun 2008
    Florida
    1997 328i E36
    I got a MM finally, but I been watching videos on how to test for drain, and it seems they all say you have to put the car in sleep mode first? But they all explain this differently and not clearly...
    If you do need to out the car to sleep first, what is the right way to do it?
    2003 ZHP 4dr
    165,000 miles
    Tires: BBS 17" rims
    Front: 225/45ZR
    Rear: 255/40ZR-17
    Answerway.com
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    The car will (should) go into sleep mode by itself after 16 minutes of inactivity. That means you can't open or close doors/hood/trunk. You can leave them open for access but they must not change. If it is an automatic transmission car, the shifter light will go out when its in sleep mode.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jun 2008
    Florida
    1997 328i E36
    Great thanks... its a 6spd but I think the 16 minute is a sound deal and someone told me the trunk light will also go out then.
    And the MM connections go to any metal ground and is it ok to plug into the negative on top of the battery? Because I dont think my battery has that other neg on the side that they show in the videos.
    2003 ZHP 4dr
    165,000 miles
    Tires: BBS 17" rims
    Front: 225/45ZR
    Rear: 255/40ZR-17
    Answerway.com
    Jun 2008
    Florida
    1997 328i E36
    And its at 0.05ma? Isnt that pretty much the norm for a car in sleep mode? I know it can go down to like 0.01 in some cars but I dont think a 0.05 would drain my battery even if left unstarted for a few days right?
    2003 ZHP 4dr
    165,000 miles
    Tires: BBS 17" rims
    Front: 225/45ZR
    Rear: 255/40ZR-17
    Answerway.com
    Jan 2016
    Ca
    2001 525it
    You can have a door open but must set the locks
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The typical drain is about 0.05 amps or 50 milliamperes. Now, if you see 0.07a or do it’s likely ok.
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by Dathaeus View Post
    I thought the meter was supposed to be connected between the battery and the negative cable, I could be wrong.
    Gave away my BMWs, driving a VW and an Audi now.
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes in series(inline)between the negative battery cable and the negative battery post-when taking amperage readings,
    not in parallel(across)as when you check battery voltage readings across both battery posts.
    Mar 2015
    west chicago il
    Quote Originally Posted by jmo69 View Post
    The battery ground cable connects to the body near the battery so it doesn't matter as long as you have a good connection.
  1. Can't figure out battery drain - Video of Parasitic Drain Test Multimeter in post
    By mfish123 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-10-2017, 07:22 PM
  2. 7-8 Amp Parasitic Drain in Sleep Mode
    By nrftball23 in forum 2004-2010 (E60,E61)
    Last Post: 02-20-2014, 07:49 AM
  3. 7-8 Amp Parasitic Drain in Sleep Mode
    By nrftball23 in forum Forum Software Questions & Suggestions
    Last Post: 02-11-2014, 12:49 PM
  4. parasitic drain test - HELP!
    By WikerMan in forum 1991 - 1999 (E36)
    Last Post: 11-22-2013, 08:14 PM
  5. hard to put car into first gear.
    By toofast4U in forum 1991 - 1999 (E36)
    Last Post: 09-02-2001, 02:49 PM
