I did a search and was surprised I didn't see a thread on this topic.
Anybody have a source for replacement sport seat foam? I have an '87 vert and the foam has deteriorated. There are foam crumbs on the floor when I vacuum the car. It needs to go in for a new top so I will likely either repair the seats with new foam or replace them with some Recaro knockoffs. I found OEM foam at ecstunig.com but ituis 1) expensive and 2) for factory cloth seats. Mine are cloth now but started as leather. Not sure how the foam is different but RealOEM shows different part numbers.
https://www.ecstuning.com/b-genuine-...h/52101933390/
https://www.ecstuning.com/b-genuine-...h/52101923907/
Thanks for any help.
Are you going to reupholster the seats? Then I'd wait until they look at them to see what needs to be done. Same if you do it yourself. You may be able just to piece some foam in.
The foam is 31 years old. It's just crumbling from age, which is why the current upholstery has to be replaced. It's actually in good shape but the foam under the upholstery is losing its shape.
