Results 1 to 4 of 4
Thread: 2.0d question
    Jan 2018
    B.C. Canada
    F25, E30, B5S4 devil car
    2.0d question
    I know this is the F30 section but from what I can tell the 2.0 diesel was much more common in this platform than the F25 (at least here in Canada, 2 years only). I hope its OK to post this here. Here goes:
    Our 2015 X3 2.8d has been to the dealer 6 times in 3 months. Grunt. (under warranty)
    CEL 1 - First they re calibrated something to do with a sensor in the exhaust.
    CEL 2 - New sensor in the exhaust
    CEL 3 - Another new sensor in the exhaust
    CEL 4 - All new exhaust system and DPF
    Latest check eng. light
    CEL 5 - Vehicle failed high RPM airflow test so: Downstream Knock sensor and the swirl flaps need to be replaced and 10+ hours of walnut blasting in the intake.
    ^Anyone had similar issues? What on earth do swirl flaps do? Will a delete (EGR) reduce intake buildup? I'm already looking to a DPF delete... or selling once the warranty is up. The hangup is my wife and I love it soooooo much when it works!
    Thanks,
    Cam
    Bellevue, WA
    335d, 328xd (had 330xi)
    Quote Originally Posted by skyoverocean View Post
    Don't know what a "downstream knock sensor" is. Also, there are several sensors in the exhaust: at least two NOx sensors, one or two O2 sensors, pressure sensors around the DPF to decide when the ash mass is high and a regeneration cycle is needed. More information is needed.
    I will say that the NOx sensors have been very problematical - BMW extended the warranty on them in the E90 335d/E70 X5d to 10/120K.
    Swirl flaps cause differing velocities in the airflow into the two intake ports and promotes better combustion. They open/close at different rpm.
    The diesel subforum is the best place to post. Might also check the X3 forums.
    Jul 2004
    Houston, TX
    36 Cylinders
    Hmm, my parents just got one of those, with low miles, and no known issues yet.
    I don't think there's a knock sensor...
    Need more detail.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2018
    B.C. Canada
    The exhaust sensors were indeed Nox sensors and I suspect the "downstream knock sensor" is probably a "downstream Nox sensor" (lost in translation)
    Ill look for the diesel sub forum, Thanks.
  1. E53 '06 3.0D - 6hp26x/z Transmission question
    By Sobek in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-15-2017, 08:39 PM
  2. Battery Question.
    By dbruce in forum 1991 - 1999 (E36)
    Last Post: 08-08-2011, 03:35 PM
  3. Qucik Question
    By mpbmw318is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-01-2001, 12:55 AM
  4. Battey Question
    By dbruce in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-27-2001, 04:53 PM
  5. O2 Sensor Questions
    By ///MCubed in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 02:08 AM
